Polaroid Ultrasonic Sensor
Trefor
PostPosted: Mon Mar 10, 2003 4:28 am     Reply with quote
Has anybody come accross any CCS C code for driving the Polaroid ultrasonic 6500 ranging board? Any help with this will be much appreciated.
Trefor
___________________________
Original Post ID: 12485
Paladdin
Re: Polaroid Ultrasonic Sensor
PostPosted: Mon Mar 10, 2003 5:02 am     Reply with quote
:=Has anybody come accross any CCS C code for driving the Polaroid ultrasonic 6500 ranging board? Any help with this will be much appreciated.
:=Trefor
Sure, but it was long ago... Programming style is rude, although enough to catch the point. Use it at your own risk :)
echo_time array returns up to four consecutive echo responses from the receiver, for multitarget measurements.
Good luck!
Paladdin
<pre>
/* RANGING.C */
#include <16C63A.H>
#define ECHO PIN_C2
#define INIT PIN_A1
#define BLNK PIN_A0
#define START_MSG '#'
#define END_MSG '*'
#define MY_ID 'A'
#use fast_io(A)
#use rs232(baud=1200,xmit=PIN_C6,rcv=PIN_C7,brgh1ok)
void check_range(void) ;
void isr_rda(void) ;
void isr_ccp1(void) ;
void csum_gen(char *s) ;
short flag = FALSE ;
long echo_time[4] ;
byte echo_counter ;
byte data_in[3] ;
#int_rda
void isr_rda(void)
data_in[2] = data_in[1] ; //Buffer 'rotativo'
data_in[1] = data_in[0] ;
data_in[0] = getc() ;
if(data_in[2] == START_MSG) //Si es para mi, reacciona
if(data_in[0] == END_MSG)
if(data_in[1] == MY_ID)
flag = TRUE ;
#int_ccp1
void isr_ccp1(void)
echo_time[echo_counter++] = CCP_1 ;
if(echo_counter > 4)
echo_counter = 3 ;
output_high(BLNK) ;
delay_us(440) ;
output_low(BLNK) ;
byte c = 0 ;
echo_counter = 0 ;
do
set_timer1(0) ;
output_high(INIT) ;
delay_ms(199) ;
output_low(INIT) ;
delay_ms(100) ;
} while((c++ < 5) && (echo_time[1] == 0)) ;
printf("#\%lu,\%lu,\%lu,\%lu,\%i*\r\n", echo_time[0],echo_time[1],
echo_time[2],echo_time[3], c) ;
for(c = 0; c < 4; c++)
echo_time[c] = 0 ;
byte c ;
set_tris_a(0x00) ;
echo_time[c] = 0 ; // Variable init
data_in[0] = '\0' ;
setup_ccp1(CCP_CAPTURE_RE) ; // Configure CCP1 to capture rise
setup_timer_1(T1_INTERNAL) ; // Start timer 1
enable_interrupts(INT_RDA) ;
enable_interrupts(INT_CCP1) ;
enable_interrupts(GLOBAL) ;
output_low(INIT) ; //Assure correct power-up
output_low(BLNK) ;
delay_ms(100) ;
if(flag)
flag = FALSE ;
check_range() ;
Original Post ID: 12488
Chromeboy
PostPosted: Tue Nov 04, 2003 8:56 am     Reply with quote
Trefor
Hi Trefor, I'm working with Polaroid modules too.
My email is fairchild@hotmail.com, so if you want to contact me to tell you everything I know.
Chromeboy
PostPosted: Tue Jan 27, 2004 4:56 am     Reply with quote
Hi Trefor, I'm very sorry, my email is NOT fairchild@hotmail.com, it is superfairchild@hotmail.com, so if you want to contact me to tell you everything I know.
Ciao.
