bauereri
| ADC Input Buffer Question |
Posted: Sun Jan 25, 2004 2:08 pm |
I'm having problems gettinig the ADC on my 16f876 to work. I've searched back through 100's of posts on this topic, and I have ideas on what I am doing wrong from a programming standpoint. However, I have a question about the proper way to connect the analog signal to the PIC.
I currently set the circuit up so that the output from a joystick pot is driving the non-inverting input of a voltage follower. I then connect the output of the follower to RA0. I ran the system like this for a very short period of time at which point the PIC started to get warm so I shut it down. If you pm me(erb@pitnet.net), I can send a bmp of the circuit for clarity. I must need to current limit somewhere, but I'm not sure where.
Thoughts are Appreciated,
Eric |
Felix Althaus
Joined: 09 Sep 2003 Posts: 67 Location: Winterthur, Switzerland
Posted: Sun Jan 25, 2004 2:27 pm |
Hi
Can you post your PIC code?
I don't see why you have to use a current limiter, the analog inputs have already a very high impedance.
May the RA0 isn't set as analog input?
mfg
Felix |
Freddie
Posted: Sun Jan 25, 2004 6:35 pm |
I think I can help you with the code part . This code takes 10 AtoD reads on RA0, averages them and sends the data out to the serial port. I use a PC terminal program to see the data. I removed some other non related code so I hope I did not introduce a syntax error. Hope this helps.
To test if the code and if your circuit is working, run the code and connect RA0 to ground and Vcc (through a pullup resistor) as a test. You should get 0x0000 and 0x03FF respectively.
#include <16F876.h>
#device *=16 ADC=10 //needed for 10 bit AtoD
#use delay(clock=10000000)
#include <string.h>
#include <stdlib.h>
#define txPC PIN_C6
#define rxPC PIN_C7
#use rs232(baud=9600, xmit=txPC, rcv=rxPC, STREAM=serialPC )
void main() {
int16 atodValue, int16Temp;
fprintf(serialPC,"\r\Running...\r\n");
setup_port_a(RA0_ANALOG); //see 16F876.h for other parameters
setup_adc(ADC_CLOCK_INTERNAL); //see 16F876.h for other parameters
while (1)
set_adc_channel(0);
int16Temp = 0;
for(i=0;i<10;i++)
atodValue = Read_ADC();
int16Temp = int16Temp + atodValue;
fprintf(serialPC, "atodValue = %LX\r\n", atodValue);
delay_ms(50);
atodValue = 0;
atodValue = int16Temp / (long)10;
fprintf(serialPC, "atodValue AVG= %LX\r\n", atodValue);
} //end while(1)
} //end main
| Re: ADC Input Buffer Question |
Posted: Mon Jan 26, 2004 8:57 am |
| bauereri wrote: | Hello,
Eric |
The key question, is what voltage range the input may go to?.
There are two basic reasons for heating in the PIC in this configuration. The first would be that the input pin was configured as an output (as has allready been suggested), while the second would be if the input signal went outside the range -0.6v to Vdd+0.6v. In this latter case, current will be drawn through the input protection diodes on the PIC.
Even if the source voltage is in the range 0v to Vdd, it is worth remembering that a op-amp wired as a voltage follower, may if not properly compensated for unity gain operation, start to oscillate. If this was happening, and the op-amp is running off (say) +/-12v, the voltages actually presented to the PIC's input, could again be driving into the protection diodes, and causing heating.
