ADC Congfiguration (vref) on 12F675
rashworth
PostPosted: Sun Jan 25, 2004 6:32 am     Reply with quote
I am trying to use Vref on the 12F675. I only require A0, as an analogue input, but I need to use A1 as the reference. How is this accomplished using the 12F675?
void Config_ADC()
      setup_adc_ports(AN0_ANALOG);//? here to set vref?
      set_adc_channel(0);
Felix Althaus
PostPosted: Sun Jan 25, 2004 6:44 am     Reply with quote
Hello
In the PIC12CE674 header file I found defined this:
AN0_ANALOG_AN1_REF
I don't know exactly the 12F675 but I bet you can use this setup constant with it.
May you want to have a look into the 12F675.H header file.
mfg
Felix
arif
PostPosted: Sun Jan 25, 2004 3:15 pm     Reply with quote
try this
it is working.
#include <12f675.h>
#device adc=10
#fuses intrc_io,noWDT,NOPROTECT,NOMCLR,NOBROWNOUT
#byte ADCON0 =0x1f
#byte ADRESL =0x9E
#bit VREFF =ADCON0.6
main()
setup_adc(internal);
VREFF=1;
while(true)
xxxxx;
rashworth
12F675 ADC Setup
PostPosted: Mon Jan 26, 2004 5:27 am     Reply with quote
Thanks Arif,
All is now working.
It appears the header file is missing some useful info for setting up the ADC reference voltage.
Rob
