float value to PC
hemnath
float value to PC
PostPosted: Thu Sep 27, 2018 11:04 pm     Reply with quote
I want to transfer float value to PC.
Compiler Version: V4.114
Sample code:
#include "18F2520.h"
#fuses HS
#include "ieeefloat.c"
float f;
int32 PCval;
int8 *p;
      f = 0.0123;
      PCval=f_PICtoIEEE(f);
      p = &PCval;  // pointer p points to the first byte of f
      putc(p[0]);  // use p as an array Send the first byte
      putc(p[1]);  // Send the second byte
      putc(p[2]);  // Send the third byte
      putc(p[3]);  // Send the fourth byte
I get the following errors:
*** Error 12 "main.c" Line 19(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 20(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 21(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 22(5,6): Undefined identifier -- putchar
hemnath
PostPosted: Thu Sep 27, 2018 11:20 pm     Reply with quote
Added the line.
Now it compiles successfully.
PostPosted: Fri Sep 28, 2018 5:06 am     Reply with quote
Be sure to add 'ERRORS' to the #USE RS232(...options...) ! While it does nothing on sending data when you have the PIC RECEIVE data, it'll keep the PIC from 'locking up'.
