Jerry Guest
Packing Messages on 18F252 |
Posted: Sun Feb 23, 2003 4:57 pm |
I was trying to implement the following example from a previous post for the 18F252.
I had no problem making it work on the 16F876.
The output shown is all scrambled. Any suggestions on what I have to change.
Thanks in advance.
#DEFINE OK_MSG 0x1FCE
#DEFINE UNK_CMD_MSG 0x1FD0
#DEFINE LEN_ERR_MSG 0x1FD8
#DEFINE NUM_ERR_MSG 0x1FE3
#DEFINE HEX_ERR_MSG 0x1FEA
#DEFINE RNG_ERR_MSG 0x1FEF
#DEFINE UNK_ERR_MSG 0x1FF9
// *** Then pack the messages up in the following fashion ***
#ROM 0x1FCE = {(128*'O'+'K'), 0 } // OK
#ROM 0x1FD0 = {(128*'U'+'n'), (128*'k'+'n'), (128*'o'+'w'), (128*'n'+' '), (128*'C'+'o'),
(128*'m'+'m'), (128*'a'+'n'), (128*'d') } // Unknown Command
#ROM 0x1FD8 = {(128*'W'+'r'), (128*'o'+'n'), (128*'g'+' '), (128*'C'+'o'), (128*'m'+'m'),
(128*'a'+'n'), (128*'d'+' '), (128*'L'+'e'), (128*'n'+'g'),
(128*'t'+'h'), 0 } // Wrong Command Length
#ROM 0x1FE3 = {(128*'N'+'u'), (128*'m'+'e'), (128*'r'+'i'), (128*'c'+' '), (128*'E'+'r'),
(128*'r'+'o'), (128*'r') } // Numeric Error
#ROM 0x1FEA = {(128*'H'+'e'), (128*'x'+' '), (128*'E'+'r'), (128*'r'+'o'),
(128*'r') } // Hex Error
#ROM 0x1FEF = {(128*'N'+'u'), (128*'m'+'b'), (128*'e'+'r'), (128*' '+'o'), (128*'u'+'t'),
(128*' '+'o'), (128*'f'+' '), (128*'R'+'a'), (128*'n'+'g'),
(128*'e') } // Number out of Range
#ROM 0x1FF9 = {(128*'U'+'n'), (128*'k'+'n'), (128*'o'+'w'), (128*'n'+' '), (128*'E'+'r'),
(128*'r'+'o'), (128*'r') } // Unknown Error
// *** This routine unpacks and transmits the messages ***
void put_ee_text(long addr) // transmit packed messages from flash
{ int ch; // unpacked character
long adr, // program memory address
xl; // packed characters
adr = addr; // copy address
while (1) // forever
{ xl = read_program_eeprom(adr++); // get packed data, auto inc address
ch = make8(xl << 1, 1); // unpack first character
if (ch == 0) break; // if null, exit
putc(ch); // transmit first character
ch = xl & 127; // unpack second character
putc(ch); // transmit second character
// *** Typical usage from some of own software ***
void send_err_msg(int err) // messages after command completion
switch ( err )
{ case 0: break; // no error, no message
case 1: put_ee_text(OK_MSG); // OK message only
case 2: put_ee_text(UNK_CMD_MSG); // Unknown Command
break; // don't type with fingers crossed
case 3: put_ee_text(LEN_ERR_MSG); // Wrong Command Length
break; // don't lean on the keybored
case 4: put_ee_text(NUM_ERR_MSG); // Numeric Error
break; // not all digits
case 5: put_ee_text(HEX_ERR_MSG); // Hex Error
break; // the spell's gone wrong
case 6: put_ee_text(RNG_ERR_MSG); // Number out of Range
break; // cowboys on the loose
default: put_ee_text(UNK_ERR_MSG); // unknown error number
send_crlf();
___________________________
Original Post ID: 12041 |
Hans Wedemeyer Guest
Re: Packing Messages on 18F252 |
Posted: Sun Feb 23, 2003 9:54 pm |
The 18F252 store two bytes per location.
Read it into a sturct/union and access one byte at a time.
Original Post ID: 12046 |
Keith Lockstone
Joined: 18 May 2004 Posts: 1 Location: Matfield, Kent, England.
Program Available for packing strings into program memeory |
Posted: Tue May 18, 2004 3:29 am |
I've done a .exe to process a text file into a .h file for #including in programs. It is designed to work with 16F887 and 18F452 processors.
Please email me if you're interested as it needs beta testing.
Keith.
(Original poster of this idea) |
