mikroe library
aaronik19
mikroe library
PostPosted: Sun Sep 16, 2018 1:25 am     Reply with quote
Dear Friends,
is it possible to use mikroe device library to CCS?
thanks
PostPosted: Sun Sep 16, 2018 3:19 am     Reply with quote
If you have this compiled, with an entry address, a function can be called by the CCS code, but if you have it as an object file, no.
PostPosted: Sun Sep 16, 2018 4:47 am     Reply with quote
Assuming you have the source, you could recode into CCS C. I did that for their PS2 KBD a very long time ago as CCS didn't have that 'driver'.
PostPosted: Sun Sep 16, 2018 5:14 am     Reply with quote
Yes. I assumed from the word 'library' that it was a pre-compiled object library. If there is code, then translate. Smile
PostPosted: Sun Sep 16, 2018 5:37 am     Reply with quote
update... a quick look on the Web and the sources (C code) for the libraries are NOT available, so code a small MikRoe C program with the desired library, compile, then dump the listing and 'decompile' or reverse engineer. You'll get real good and understanding PIC ASM this way !
What I don't know is if a 'library' contains say 4 functions, if ALL of the functions are compiled or only the one you call. That's your homework.
Jay
