Shift Left a complete 128 bytes Array of 1 bit
Manu59114
PostPosted: Sun Sep 16, 2018 2:53 am     Reply with quote
Hello to all!
I'm trying to shift left a 128 bytes Array of 1 or 2 bits!
unsigned int8 Array[128];
Of course, the MSB of Array[0] should become the LSB of array[1]..and so on
Can you open my eyes to the way to do that?
Thank you very much.
Wish you all the best!
Manu
CCS + ICD3 + PIC18F46K80
PostPosted: Sun Sep 16, 2018 3:17 am     Reply with quote
The compiler's shift_left function.
shift_left(Array,128,0);
Will shift all 128 bytes, propagating the bits from byte to byte as you describe (this will put '0' into the right hand bit).
Manu59114
PostPosted: Sun Sep 16, 2018 3:53 am     Reply with quote
Many thanks!!! it's works like a charm.
I'm the happiest man because...since i tell to my wife that my work is finished for this Sunday morning....and we can go to the restaurant!!!,
Thanks again Ttelmah!
Wish you a great Sunday!
Manu
PostPosted: Sun Sep 16, 2018 5:12 am     Reply with quote
That's a successful outcome!. Smile
asmallri
PostPosted: Sun Sep 16, 2018 11:46 pm     Reply with quote
Manu
A great outcome. The operation you are doing is actually a rotate. if you are regularly doing this, for example to drive christmas lights, then a much more efficient way to do this is to have two single byte indexes. The first points to the byte that holds the current offset into the array of the byte containing the first bit in the sequence and the second byte contains a bit mask pointing to the current bit. Instead of rotating the array you rotate the mask. if after rotating the mask, the byte value of the mask is zero then you set it to 1 (actually 0x01) and increment the offset pointer. If this pointer equals the size of the array then set it to 0
Seems more complex but significantly faster.
Regards, Andrew
