function pointers are not ready for prime time
bartholomew
PostPosted: Fri Sep 19, 2003 1:15 am     Reply with quote
So I just wasted most of a day trying to get function pointers to work in CCS. My experience is that the implementation is incredibly buggy.
(I'm using 3.173 -- haven't updated to 3.178 because the release notes don't suggest that these poblems have been fixed, and last time I updated on a whim I lost another day's work.)
Here's an example of what I mean by buggy:
The following compiles fine:
#include <18f452.h>
 typedef int1 bool;
 typedef bool (*FuncFoo) ();
The following code (functionally identical) fails to compile with error:
Error[38] ... This type can not be qualified with this qualifier
#include <18f452.h>
typedef int1 (*FuncFoo) ();
Does this sort of thing drive anyone else mad?
-bart
bartholomew
another example...
PostPosted: Fri Sep 19, 2003 1:25 am     Reply with quote
Here's another example of function pointer bugginess.
#include <18f452.h>
typedef int (*FuncFoo) ();
int foo() {
    // do nothing
    FuncFoo someFunction;
    someFunction = foo;
    (*someFunction)();
However if I comment out the last line (*someFunction)(); I
get:
Error[44] ... Internal Error - Contact CCS LABEL SCR = 356
and if I leave it commented out but make someFunction global, I get:
Error[44] ... Internal Error - Contact CCS LABEL SCR = 354
Anyway, generally CCS is happy to assign foo to someFunction, but what if the assignee is part of a struct?
#include <18f452.h>
int foo() {
    // do nothing
struct {
} gFuncStruct;
    gFuncStruct.someFunction = foo;
In this case, CCS errors out with
Error[117] ... Improper use of a function identifier
What does this mean?
-bart
bartholomew
third example of function pointer bugginess...
PostPosted: Fri Sep 19, 2003 1:33 am     Reply with quote
Here's my last example for the day of why CCS's function pointer implementation is not ready for prime time.
The following code compiles fine:
#include <18f452.h>
typedef void (*FuncNothing) (char c);
typedef char (*FuncReceive) ();
FuncNothing sFuncNothing;
void nothing(char c) {
    // do nothing
void neverCalled() {
    sFuncNothing = nothing;
Yes I know that it is pretty pointless code, but it is analogous to a heap of code I just wrote. Anyway, suppose I swap the order of the two typedefs, so the code is as follows:
When I do the above, I get the error:
Error[118] ... Invalid type conversion
Can you imagine how frustrating it is to track down bugs when the order of typedefs matters to CCS? Has anyone put together a list of what works and what doesn't with function pointers?
Downloading MPLABŪ C18 free demo now to see if Microchip do it any better...
-bart
Darren Rook
PostPosted: Fri Sep 19, 2003 7:52 am     Reply with quote
I thought pointers to functions were beta. In fact, I don't think they've even been documented yet.
PostPosted: Thu Jan 15, 2004 10:15 am     Reply with quote
after ver 3.160 function pointers are supported
PostPosted: Thu Jan 15, 2004 10:47 am     Reply with quote
You're talking about this comment:
"3.160 Pointers to functions are now supported"
on the versions page, http://www.ccsinfo.com/versions.shtml
For your information, just because CCS announces something
there, it doesn't mean that it's fully tested. It means that
they've newly added it as a feature. It may, and often does,
have bugs for a while.
Darren Rook
PostPosted: Thu Jan 15, 2004 12:03 pm     Reply with quote
Yes, beta.
Support added, not documented. Also "supported added" in the version update page doesn't mean full support added.
Progress has to start somewhere.
You've put a lot of work and thought into this, please e-mail everything to CCS - including source code, .lst file, and description of each problem.
h
PostPosted: Thu Jan 22, 2004 1:42 pm     Reply with quote
so, when do you think function pointers will be ready for everyday use?
