Jeetdesai
| How to transmit characters/special characters over SPI? |
Posted: Tue Jul 10, 2018 8:44 am |
I can successfully transmit decimal, hex and binary data over SPI. I check my signals by connecting the oscilloscope probes at the data out, clock and enable pins, and observe the waveforms.
But i'm getting the wrong data when I send characters(A, B ... Z)) or special characters(!, @ ... +). The waveform on the output is the same (01100111) for all alphabetic characters and special characters.
The following is my code:
| Code: | #include <18F87K22.h>
//#FUSES NOPUT //No Power Up Timer
#FUSES NOPROTECT //No code protected from reads
//#FUSES BROWNOUT // Hold in reset during brownout - else can corrupt EEPROM, act strange, etc
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use delay(clock = 1000000)
#define CS Pin_H0
//#BYTE ODCON1=
//#BIT ODCON1BIT7 = ODCON1.7
/*#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H) */
setup_spi(SPI_MASTER | SPI_H_TO_L| SPI_CLK_DIV_64);
output_low(CS);
//spi_write(0x55); //hex data
//spi_write(75); // decimal
//spi_write(0b11110000); // binary
spi_write("A"); //Char data
output_high(CS);
delay_us(1000);
Posted: Tue Jul 10, 2018 9:34 am |
| Quote: | | spi_write("A"); //Char data | This is not the correct way to do it.
The correct way is to use single quotes:
Jeetdesai
Posted: Tue Jul 10, 2018 9:46 am |
| Thanks You so much !!! |
