Program stopping in the delay () function
jacktaylor
PostPosted: Wed Jul 04, 2018 8:40 am     Reply with quote
Friends, good afternoon. Can anybody help me? I do not know why any timed line increased below the trigger(); prototype is not executed while looping (true). It looks like the program for in delay(). If you remove the delay, the loop is executed by executing the trigger(); is really very strange. Program stopping in the delay() function;
#include <16F877A.h>
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#use delay(clock= 20M)
//--->>>>>>>>>> O programa funciona sem estas diretivas fast_io nem tris_x
#use fast_io(c)
//*******COnecoes LCD*********
#define LCD_DB4   PIN_A4 // Pino bloco dados 4 no pino microcontrolador
#define LCD_DB5   PIN_A3
#define LCD_DB6   PIN_A2
#define LCD_DB7   PIN_A1
#define LCD_RS    PIN_E0
#define LCD_E     PIN_A5
#include <lcd4bitsMicrostronic.c>
#define trig    PIN_C1
// --- Protótipo da Função Auxiliar ---
void trigger();
// --- Variáveis Globais ---
      //Configura PORTS
      SET_TRIS_C(0X04); // C2 configurado como entrada, pois é o ECHO DO SENSOR e CCP1 do PIC. C1 é TRIG do 16F877A para sensor, ENTAO SAIDA.
      output_c(0x00);
      Enable_Interrupts(GLOBAL);
      DISABLE_INTERRUPTS(INT_TIMER1);
      Enable_Interrupts(INT_CCP1 );  // USEI CCP1IE  = 0x01; Habilita interrupção do periférico CCP
      Setup_ccp1(CCP_CAPTURE_FE);   //  CCP1CON  = 0x04; CONFIGURA BYTE BORDA SUBIDA NOREGISTADOR
      Setup_Timer_1(T1_INTERNAL|T1_DIV_BY_2);
      //Inicializa LCD
      lcd_init();
      lcd_putc("\f");
      lcd_gotoxy(1,1); //lcd_gotoxy para coluna, linha
      printf(lcd_putc,"distancia");
      lcd_gotoxy(14,2); //lcd_gotoxy para coluna, linha
      printf(lcd_putc,"cm");
      trigger();                               //Chama a função de trigger
      delay_ms(100);                           //lEITURA DO PULSO A CADA 100ms Taxa de atualização
   } //end while
}// end void main
      //TODO: User Code
void trigger()
  output_high(trig); // trih = 0x01; trig em nível high
  delay_us(10);      //por 10 micro segundos
  output_low(trig); //trig = 0x00;
} //end trigger
PostPosted: Wed Jul 04, 2018 9:06 am     Reply with quote
There is no sign of an interrupt handler for CCP1. The code will crash without this.
jacktaylor
PostPosted: Wed Jul 04, 2018 9:59 am     Reply with quote
Even commenting on all the configuration lines of the CCP1 module, the program is stopped in delay (); Commenting on the delay, the program executes the while (1) {trigger ();}
Note below.
Why is this happening?
#use fast_io(c)
#define trig    PIN_C1
void trigger();
      //Configura PORTS
      output_c(0x00);
//!      Enable_Interrupts(GLOBAL);
//!      DISABLE_INTERRUPTS(INT_TIMER1);
//!      Enable_Interrupts(INT_CCP1 );  // USEI CCP1IE  = 0x01; Habilita interrupção do periférico CCP
//!      Setup_ccp1(CCP_CAPTURE_FE);   //  CCP1CON  = 0x04; CONFIGURA BYTE BORDA SUBIDA NOREGISTADOR
//!      Setup_Timer_1(T1_INTERNAL|T1_DIV_BY_2);
      //Inicializa LCD
//!      lcd_init();
//!      lcd_putc("\f");
//!      lcd_gotoxy(1,1); //lcd_gotoxy para coluna, linha
//!      printf(lcd_putc,"distancia");
//!      lcd_gotoxy(14,2); //lcd_gotoxy para coluna, linha
//!      printf(lcd_putc,"cm");
//!      delay_ms(100);
   } //end while
}// end void main
      //TODO: User Code
void trigger()
} //end trigger
PostPosted: Wed Jul 04, 2018 10:02 am     Reply with quote
Are you running this 'for real' , or in a simulator?.
In a simulator, a delay can take ages to execute.
If 'for real', are you sure you will see/detect a 10uSec pulse every 100mSec?.
jacktaylor
PostPosted: Wed Jul 04, 2018 10:57 am     Reply with quote
It's you absolutely right. In the simulator without the delay_us (100);, I have the signal of the trigger and I can measure 10us of signal with ease in the virtual oscilloscope, when I put the delay_ms (100), it becomes more complicated to read the signal of 10us. In actual assembly I try to work the Echo signal of the Ultrasonic Sensor HC-SR04. And I was having problems with the Echo signal, so I was reducing the program until I got to the trigger. The ideal is to have even a real oscilloscope. Thank you Ttelmah.
