Difference between PORT and PIN
srikrishna
PostPosted: Wed Jun 06, 2018 1:48 pm     Reply with quote
What is the difference between PORT and PIN?? Are they same??
I have searched in the internet but did not get satisfactory answer.
PostPosted: Wed Jun 06, 2018 1:56 pm     Reply with quote
You are asking questions about Atmel microcontrollers. That's off topic on
the CCS forum.
Use Google and search for this:
atmel ddra porta pina
srikrishna
PostPosted: Wed Jun 06, 2018 2:14 pm     Reply with quote
the CCS forum.
Are they same for PIC ???
PostPosted: Wed Jun 06, 2018 2:25 pm     Reply with quote
PORT is typically a collection of I/O pins that can be accessed at one time. PORTs can be 1 bit wide, 4 bit wide, 8 bit wide, 16 bit wide or more (or less) depending on the device being used (and the 'mode').
PIN generally means a single 'pin', which can be Input/Output, input only or output only.
srikrishna
PostPosted: Wed Jun 06, 2018 2:28 pm     Reply with quote
temtronic wrote:
Thanks Very Happy
