shift_right help please
Kasper
PostPosted: Tue Jan 20, 2004 1:45 pm     Reply with quote
Hi.
in trying to implement the below code, the compiler keeps giving me an error:
*** Error 28 "..." Line 86(32,45): Expecting an identifier
looking at the manual, I cannot really tell what I am doing wrong here :(
Any help would be appreciated
Compiler: 3.184, WinXP, 16F877, ICD2
This is what it says in the manual:
// This shifts 8 bits out PIN_A0, LSB first.
for(i=0;i<8;++i)
output_bit(PIN_A0,shift_right(&data,1,0));
#define ReceiveBufferSize 25
char ReceiveBuffer[ReceiveBufferSize];
main() {
for(i=0;i<(8*ReceiveBuffer);i++) {
   output_bit(pin_a0,shift_right(&ReceiveBuffer,1,0));
   output_high(S2);
   delay_us(TCLKH);
   output_low(S2);
   delay_us(TCLKL);
   }// end of for.
}// end main
[/quote]
PostPosted: Tue Jan 20, 2004 5:40 pm     Reply with quote
The problem is in this line:
ReceiveBuffer is an array, and in C, the name of the array, used by
itself, is the address of the 1st element. You don't need the & symbol.
That's why the compiler is complaining.
Another way to get the address of the 1st element is this:
&ReceiveBuffer[0]
I do have one question. Your ReceiveBuffer array has 25 elements,
but you have set the middle number in the shift_right() function = 1.
This will cause it to only shift the first array element. Based on
the rest of your code, I think you really want to set it = 25.
ie., the corrected line should look like this:
output_bit(PIN_A0, shift_right(ReceiveBuffer, RECEIVE_BUFFER_SIZE,0));
