volatile pointer to volatile data
bmitchell2407
PostPosted: Fri May 11, 2018 3:24 pm     Reply with quote
Hi, new to the forum here.
It seems that CCS cannot create a volatile pointer to volatile data as in:
volatile int8 * volatile p;
I think this is correct standard C code, but the compiler doesn't like this. I want to use this because I have a pointer used in an ISR where the data changes and the pointer changes.
Has anyone else tried to do this?
Thanks!
PostPosted: Sat May 12, 2018 2:15 am     Reply with quote
I agree it doesn't compile with vs. 5.078 (PCH compiler).
If you post a very small but complete test program we could see
if it's actually necessary with CCS.
PostPosted: Sat May 12, 2018 8:45 am     Reply with quote
'Volatile' has almost no effect in CCS code. The PIC12, 16 & 18, don't have any temporary registers (only W), so everything is always read each time it is used from the physical memory. This differs from other processors (and the PIC24/30 etc.), which have 'working' registers. Volatile is meant to ensure that the code will not store things into temporary registers, but instead always read from the memory. Now I haven't looked for the DsPIC's where volatile might have an effect, but on the standard PIC's it doesn't....
asmallri
PostPosted: Sun May 13, 2018 10:22 pm     Reply with quote
I agree with this:
But not completely with this:
The PIC18 does have other temporary registers, such as the PRODH and PRODL registers. I have used these as working registers in the past. I also consider the address space in the access bank for the to be fair game for temporary registers
Regards, Andrew
PostPosted: Mon May 14, 2018 1:08 am     Reply with quote
What 'volatile' is meant to prevent is the situation where (for instance) a port value is read and tested, with a loop till it is zero, which once optimised by the compiler, does not reload the physical port value after the first test. However CCS does not do this. If a value is tested, it will be retested every time round the loop.
Being 'globally volatile', is potentially inefficient. However the choices in the PIC are quite limited in this regard. Areas that would gain from being non volatile are the PROD registers (as pointed out above), but little else. The compiler won't sit assuming that "I tested that a moment ago, it can't have changed". If asked to test, it will test.
There are issues that the programmer has to deal with (such as multi byte values being updated between operations by an interrupt), but these are separate.
A 'classic' volatile demo, is;
   int a=0;
   while (a==0)
Which with a 'non volatile' variable 'a' can become optimised to looping for ever without testing a again (after all it is zero....). However with 'a' declared as volatile the loop has to load 'a' and actually test it. So if the value does get changed in an interrupt for example, the code will exit the loop. CCS does this by default.
RF_Developer
Re: volatile pointer to volatile data
PostPosted: Mon May 14, 2018 4:37 am     Reply with quote
I do not know why the compiler rejects this syntax. We are just users - this is a self-help forum - and are not CCS and do not have any knowledge of or control over their compiler implmentation.
However, I have never used such a syntax, mainly because its very rare that it would ever be of practical use, except in C syntax exercises. Volatile pointers are common: I/O buffer pointers for example. In that case, the fact that the pointer changes"under" the code indicates that the data itself also changes. For this the volatile pointer syntax is fine:
int8 * volatile p;
but also, in the case of CCS code, unnecessary for the reasons Ttelmah outlined. Hence this is rarely seen in CCS code, even if seen as "correct" from a purist C perspective. Or more to the point, volatile tends to be used to solve problems, but if, as in CCS C, the particular problems its used to solve don't happen, then volatile tends not to be used, even if it is "correct" C. Even where volatile could be useful, for example to solve non-atomicity issues such as int16/32s changed in an ISR on PIC 18s, people tend to get round the issue in other ways, such as the "read twice" method, or even, arguably more appropriate to the hardware but also hardware specific, by critical section locking, but then this particular issue is hardware specific. I don't know if volatile actually works in that scenario, as I tend toward critical sections.
The volatile pointer to volatile data scenario would be for situations where the pointer can change and the data can change *without* a change in the pointer, i.e. the two were independant, which is rare.
So, its rare to see volatile in CCS code, and while its somewhat saddening that it doesn't compile, seeing two volatiles in one declaration is exceptionally rare to the point of being endangered.
PostPosted: Mon May 14, 2018 6:54 am     Reply with quote
Where volatile become massively important is on systems that can cache large amounts of what they are actually doing.
This is the best post I know about volatile, especially the reference for where it comes from:
<https://blog.regehr.org/archives/28>
Note the comment about a simple C.
