Posted: Sat May 12, 2018 1:47 am |
newguy wrote: |
64MHz: misshapen positive offset 0.5Vp-p waveform out.
48MHz: misshapen positive offset 1.5Vp-p waveform out.
32MHz: proper rail-rail output square wave.
16MHz: proper rail-rail output square wave.
12MHz: proper rail-rail output square wave.
8MHz: proper rail-rail output square wave.
4MHz: misshapen positive offset 2Vp-p waveform out.
2MHz: misshapen positive offset 1Vp-p waveform out.
1MHz: misshapen positive offset 0.5Vp-p waveform out.
I ran all your freqs on my 18F47K40 and got the results shown below:
48MHz: misshapen positive offset 1.0Vp-p waveform out.
32MHz: not a perfect square wave, 0.2v to 3.3v waveform out
4MHz: proper rail-rail output square wave.
1MHz: proper rail-rail output square wave.
This makes more 'sense' as it starts failing at 32 MHz a little bit
and gets worse the higher you go.
PIC Silicon rev: a003
Date code: 1729YAK
Package: PDIP-40
Supplier: Digikey
Vdd voltage: 3.3v
Programmer: Pickit 3
Programmer software: Microchip IPE vs. 4.15
Compiler IDE: Microchip vs. 8.92
CCS Compiler vs.: 5.078
Also, I tested it at 5v for the 48 and 64 MHz freqs. Same results.
You could add this data to your trouble ticket. |
Posted: Sat May 12, 2018 2:43 am |
Suggestion.
Clear the SLRCON registers. SLRCONA, SLRCONB & SLRCONC. Do something like:
#byte SLRCONA=getenv("SFR:SLRCONA")
#byte SLRCONB=getenv("SFR:SLRCONB")
#byte SLRCONC=getenv("SFR:SLRCONC")
//Then in your main
SLRCONA=SLRCONB=SLRCONC=0;
These all default to '1' which implies slew rate limiting is enabled. Though the limitation should still allow the clock rates involved, it's worth trying with this off.... |
Posted: Sat May 12, 2018 2:55 am |
Yes Ttelmah, that fixed it for all the higher frequencies. Thanks. |
newguy
Posted: Sat May 12, 2018 8:09 am |
Ttelmah wrote: | Suggestion.
//Then in your main
I'll try that Monday. Thanks! |
Posted: Sat May 12, 2018 8:52 am |
It's interesting since it seems to suggest that the actual slew rate limits are 'worse' than the data sheet suggests. However at least we have a 'reason' now.
The slew rate limit is meant to limit the rise and fall times to 25nSec each, which should allow a cycle at 50nSec, so 20MHz. It suggests it's actually giving perhaps half this....
It does say "These parameters are characterized but not tested" for the maximum slew time.
I looked at this, when the clock reference module gave the same behaviour, since this implied the problem was with the output pin drive itself, and not the signal feeding it. |
newguy
Posted: Mon May 14, 2018 12:41 pm |
Confirmed, the slew rate control was preventing both the CLKOUT and CLKR signals from reaching their full output excursion and thus was limiting the apparent bandwidth. Thanks Ttelmah. |
