PIC18F25k42 Interrupts Not Working - At all
Goto page 1, 2  Next
asgudeman
PostPosted: Wed Apr 25, 2018 6:20 pm     Reply with quote
I am very new to CCS, but have been using XC8-32 for about 6-7 years.
I am just trying (at this point) to make a timer interrupt do just that, interrupt.
I have checked PIE registers, TIMxCON registers. All are where they are supposed to be.
Here is a sample of the code (the entire set is too big to copy)
#include <18F25K42.h>
#device PIC18F25K42
#device ICD=TRUE
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES RSTOSC_HFINTRC_64MHZ
#FUSES NOCKS                    //Clock Switching Disabled
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#use delay(internal=64M)
    // Use TIM2 as SysTick timer (1 ms)
    // (1/64000000)*4*128*125 = 1000 us or 1.0 kHz
    setup_timer_2(T2_DIV_BY_128, 125, 1);
#INT_TIMER2
void TIMER2_isr(void)
    sys_time++;
I tried this exact same code on an evaluation board (different processor of course), and we were firing interrupts left and right. However, I can't get any to work on this specific chip. Any leads or help would be GREATLY appreciated. THANK YOU.
PostPosted: Wed Apr 25, 2018 8:49 pm     Reply with quote
And what is your CCS compiler version ? The K42 parts are new and
CCS is still making changes. List of versions:
http://www.ccsinfo.com/devices.php?page=versioninfo
asgudeman
PostPosted: Thu Apr 26, 2018 9:23 am     Reply with quote
I am using 5.078 CCS compiler with MPLAB X v4.05
pmuldoon
PostPosted: Thu Apr 26, 2018 10:53 am     Reply with quote
shouldn't there be a clock source for the timer setup? maybe it's defaulting to an external input.
Try adding T2_CLK_INTERNAL to the setup.
pmuldoon
PostPosted: Thu Apr 26, 2018 11:03 am     Reply with quote
looking at the device.h file, it looks like it defaults to T2_CLK_T2IN which is an external input.
try
setup_timer_2(T2_DIV_BY_128 | T2_CLK_INTERNAL, 125, 1);
PostPosted: Thu Apr 26, 2018 12:15 pm     Reply with quote
and the divider needs to be 124, not 125. The division is by PR2+1. So to divide by 125 you have to load 124.
asgudeman
PostPosted: Thu Apr 26, 2018 3:19 pm     Reply with quote
I have tried putting all [spam] sources just to force an interrupt - but to no avail. The divider value is just for show right now, just trying to get basic interrupt functionality. What is the likelihood that the .h file has the vectors mapped wrong? Low?
asgudeman
PostPosted: Thu Apr 26, 2018 6:34 pm     Reply with quote
Could this be a thing where the specific target isn't fully supported with debug by a Microchip ICD3 debugger?
PostPosted: Fri Apr 27, 2018 12:25 am     Reply with quote
Don't get me wrong, but I compiled:
int16 sys_time=0; //Omitted from posted code
    setup_timer_2(T2_DIV_BY_128 | T2_CLK_INTERNAL, 124, 1);
#INT_TIMER2
    sys_time++;
And running in the current MPLAB simulator, it merrily increments 'sys_time'.
I'd be looking at your debugging environment.
pmuldoon
PostPosted: Fri Apr 27, 2018 5:16 am     Reply with quote
You might want to try adding a line of code in the main loop that turns an LED or at least an unused PIC output pin on/off based on the value of sys_time.
Be careful, though. You have a 16-bit value you are changing in the interrupt and also reading in the main program. It's possible for the interrupt to occur while it's in the process of being evaluated in the main program.
asgudeman
PostPosted: Fri Apr 27, 2018 4:03 pm     Reply with quote
Are you using a later version of MPLAB X? I have 4.05 currently installed with all the plugins I could find
PostPosted: Fri Apr 27, 2018 11:02 pm     Reply with quote
Just the current version 4.15. 4.05 is quite old.
asgudeman
PostPosted: Mon May 07, 2018 5:31 pm     Reply with quote
All,
I went ahead and ordered the PIC U64 device so I could more fluidly develop in the CCS compiler. Still no interrupts firing. Heck, I am having difficulty getting this program to have step-through capability. Any other ideas?
asgudeman
PostPosted: Mon May 07, 2018 6:04 pm     Reply with quote
Checking interrupt vectors right now, but timers 0, 1, 3... dont work with interrupts while timers 2, 4, 6... do.
I havent checked the comparator yet
PostPosted: Mon May 07, 2018 8:20 pm     Reply with quote
I can buy one and check the problem. The reason I didn't do it so far
is quite often, the person will come back and say, I'm sorry I left off the
bypass caps or the Mclr circuit and now it works OK.
If you can assure me that everything is correct circuit-wise, I'll order
that PIC and test it.
One question is, have you tested the interrupts without using the debugger ?
Just test it in a Release Mode program. Blink an LED to prove it's in
the interrupt routine or output a character with putc(). Something simple.
Goto page 1, 2  Next
Page 1 of 2
