RN2903 Wake up
cvargcal
RN2903 Wake up
PostPosted: Wed Mar 21, 2018 4:30 pm     Reply with quote
Hi I need Wake up this module, but I can not get...
The manual say its necessary a "break condition" how I can do?
http://ww1.microchip.com/downloads/en/DeviceDoc/40001811A.pdf
for sleep module
 fprintf(lora,"sys sleep 40000\r\n");   // // Enter sleep mode for 40 seconds
for wake up
output_low(TXD_Lora);   // Start break signal on MCU TX pin
delay_ms(1000);;
 output_high(TXD_Lora);   // Start break signal on MCU TX pin
 fprintf(lora, 0x55);          // Send magic break character (auto bauding)
But not work
asmallri
PostPosted: Wed Mar 21, 2018 4:38 pm     Reply with quote
This would not create a break condition because the uart is mapped to the serial port. To use this mechanism you would need to close the serial port, send your break, then open the serial port.
Alternatively, you could wake the module via toggling the reset line. This is the mechanism I use.
Regards, Andrew
cvargcal
PostPosted: Wed Mar 21, 2018 5:07 pm     Reply with quote
Thanks, I use that PIN RESET, but I did many PCB and not put that wire...because I need wake up and not Reset
asmallri
PostPosted: Wed Mar 21, 2018 6:38 pm     Reply with quote
You need the CCS equivalent of this:
void wakeUP_RN2483() {
    Serial1.end();
    pinMode(PIN_SERIAL1_TX, OUTPUT);
    digitalWrite(PIN_SERIAL1_TX, LOW);
    delay(5);
    digitalWrite(PIN_SERIAL1_TX, HIGH);
    Serial1.begin(57600);
    Serial1.write(0x55);
Regards, Andrew
cvargcal
PostPosted: Wed Mar 21, 2018 11:46 pm     Reply with quote
    Serial1.end();
    delay(5);
Yes I tried use this
#include <18F4550.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP, CPUDIV1
#define BAUDRATE 9600
#define TX_PIN  PIN_C6
#define RX_PIN  PIN_C7
#use rs232(baud=BAUDRATE, xmit=TX_PIN, rcv=RX_PIN, ERRORS)
void send_break(int8 time_ms)
// Disable the UART and send a Break
// for the specified time.
setup_uart(FALSE);
output_low(TX_PIN);
delay_ms(time_ms);
// Re-enable the UART.
setup_uart(TRUE);
set_uart_speed(BAUDRATE);
int8 c;
printf("Start:\n\r");
send_break(20);
   c = getc();  // Get a char from the PC
   putc(c);     // Send it back to the PC
But no work, I have this
#BIT TX_S = 0xF94.6 // Pin direction mapped to TRISC.6
#BIT RX_S = 0xF94.7 // Pin direction mapped to TRISC.7
#define BAUDRATE 57600
#define TXD_Lora     PIN_C6    // TXD_Lora
#define RXD_Lora     PIN_C7    // RX_Lora
#use rs232(baud=BAUDRATE,xmit=TXD_Lora,rcv=RXD_Lora,bits=8,parity=N,ERRORS,stream=lora)  // Modulo RN2903
//!#use rs232(baud=57600,xmit=PIN_c6,rcv=PIN_c7,bits=8,parity=N,ERRORS,stream=lora)  // Modulo RN2903
#use rs232(baud=9600,xmit=PIN_b6,rcv=PIN_b7,bits=8,parity=N,ERRORS,stream=debug)  // Puerto DEBUG
    setup_uart(FALSE,lora);             //Serial1.end();
    TX_S=0;                               //pinMode(PIN_SERIAL1_TX, OUTPUT);
    output_low(TXD_Lora);             //digitalWrite(PIN_SERIAL1_TX, LOW);
    output_high(TXD_Lora);             //digitalWrite(PIN_SERIAL1_TX, HIGH);
    set_uart_speed(BAUDRATE,lora);          //Serial1.begin(57600);
    fprintf(lora,0x55);             //Serial1.write(0x55);
So I don know how "disable" de lora port
There is other code
but how write in CCS?
void RNsleep(void)
  UART_Write_Text("sys sleep 400000000");
  delayXs(1);
void RNwakeUp(void)
while(!TRMT);
TXREG = 0x00;
while(!TRMT);
TXREG = 0x55;
PostPosted: Thu Mar 22, 2018 1:23 am     Reply with quote
void send_break(int16 time_ms) //note int16
   setup_uart(FALSE);
   output_low(TX_PIN);
   delay_ms(time_ms);
   // Re-enable the UART. - sending 'non zero', enables and sets the
   //baud rate
   setup_uart(BAUDRATE);
   putc(0x55); //The character after the break _[u]must[/u]_ be 0x55
   int8 c;
   delay_ms(500); //give time for other things to wake
   send_break(20);
What you have would work, except you are missing the 0x55 character that must follow the break. Also you don't need to set the baud rate separately. The setup_uart command can do this in one operation.
Note also the delay. Any module like this (running firmware), takes time to boot. Most need perhaps 100mSec, before they can accept commands after power-on. I can't see anything in the data sheet saying how long it does need, but 'history' says a delay before trying to change the baud rate is probably sensible....
kmp84
PostPosted: Thu Mar 22, 2018 2:56 am     Reply with quote
I'm also using RN2483 Lora modem in peer to peer mode with hardware reset pin without problem.
Best Regards!
asmallri
PostPosted: Thu Mar 22, 2018 12:05 pm     Reply with quote
FYI, I tested this with current generation RN2903A modules. It consistently takes 4.6ms to be ready from a software reset or hardware reset. I chose this method over the wake / break sequence because I thought it was cleaner.
Regards, Andrew
PostPosted: Thu Mar 22, 2018 12:50 pm     Reply with quote
Useful data. I'd say to use 10mSec to be safe then. Smile
cvargcal
PostPosted: Thu Mar 22, 2018 2:42 pm     Reply with quote
Thanks to everyone.
I did this:
#include <18LF26K22.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
void blink_led(PIN,int1 time_up,int time_down );
void send_break(int16 time_ms){
   // Disable the UART and send a Break  for the specified time.
   setup_uart(FALSE);
   output_low(TX_PIN);
   delay_ms(time_ms);
   // Re-enable the UART. - sending 'non zero', enables and sets the baud rate
void main(void) {
   char c;
    while(TRUE){
              c=0x00;
              printf("sys sleep 20000\r\n");
              delay_ms(4000);
              send_break(200);
              printf("sys get ver\r\n");
              delay_ms(200);
              c = getc();
             if (c=="R")   blink_led(pin_c5,20,50);
//******* Blink LED *********************
void blink_led(PIN,int1 time_up,int time_down ){
      output_high(PIN);      delay_ms(time_up);
      output_low(PIN);       delay_ms(time_down);
but not work... the module not wake up
I not wanted use the PIN RESET... but to end I have do it.
What is the diference if I reset the module to Wake up?...
maybe its better RESET
PostPosted: Thu Mar 22, 2018 3:52 pm     Reply with quote
Does your PSU meet the supply rise time requirements for the unit?. If not, the chip may not be resetting properly on power on. Remember the chip has to have successfully booted, before you can use the 'break' command sequence.
cvargcal
PostPosted: Tue Aug 07, 2018 11:18 pm     Reply with quote
Ttelmah wrote:
I am again here.... I saw this example from microchip, so how I do on CCS?
please
void moduleResync(void)
    // First send wake up / restart autobaud
    TXSTAbits.TXEN = 0;
    EUSART_TX_LAT = 0;
    _delayms(10);
    TXSTAbits.TXEN = 1;
  _delayms(5);
    // Now send autobaud detect character
    TXREG = 0x55;
    while (TXSTAbits.TRMT == 0)
    // Now send a command to be ignored
    sendCommand("z");
PostPosted: Wed Aug 08, 2018 1:07 am     Reply with quote
Er something like:
    setup_uart(FALSE); //turn off the UART
    output_low(TX_PIN); //select to suit your UART
    delay_ms(10);
    setup_UART(TRUE); //turn UART back on
    delay_ms(5);
    putc(0x55);
Then you would need whatever the 'sendcommand' code has in it.
The autobaud here is for the remote device not the PIC, so it doesn't have to do anything except send a break (which is what turning off the UART, and dropping the TX pin does), and then send the sync character (0x55) to the remote device.
