How to setup ADC port on 16F819 ?
sorasit46
PostPosted: Tue Mar 13, 2018 8:22 am     Reply with quote
Hi!
I am using AN4 for analog input signal.
#include <16F819.h>
#device  adc=10
#FUSES   INTRC_IO,WDT
#FUSES   NOPUT,NOMCLR,NOBROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG,NOPROTECT
#use     delay(clock=4000000)
#byte    OSCCON = 0x8F
#use     fast_io(A)
#use     fast_io(b)
float    Vreadch;
int1     led1,led2;
void     main()
 setup_oscillator(OSC_4MHZ);
 disable_interrupts(GLOBAL);
 setup_timer_0(RTCC_DIV_8);
 setup_timer_1(T1_DISABLED);
 setup_adc_ports(AN4);
 port_b_pullups(TRUE);
 setup_spi(FALSE);
 set_tris_A(0b00010000);
 set_tris_b(0b00000000);
 setup_wdt (WDT_2304MS);
 while (true)
        set_adc_channel(4);delay_us(20);
        Vreadch = read_adc();delay_us(20);
        restart_wdt();
Compile report
***Error12"wash.c"Line26[18,21]:Undefined Identifier AN4
How to set up port for AN4 pin ?
Best regard
gaugeguy
PostPosted: Tue Mar 13, 2018 8:38 am     Reply with quote
Open the 16F819.h file and look at the constants allowed for the setup_adc_ports function.
sorasit46
PostPosted: Tue Mar 13, 2018 5:22 pm     Reply with quote
16f819.h
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS                           7    // None
#define ALL_ANALOG                           0    // A0 A1 A2 A3 A4
#define AN0_AN1_AN2_AN4_VSS_VREF             3    // A0 A1 A2 A4 VRefh=A3
#define AN0_AN1_AN3                          4    // A0 A1 A3
#define AN0_AN1_VSS_VREF                     5    // A0 A1 VRefh=A3
#define AN0_AN1_AN4_VREF_VREF             0x08    // A0 A1 A4 VRefh=A3 VRefl=A2
#define AN0_AN1_VREF_VREF                 0x0D    // A0 A1 VRefh=A3 VRefl=A2
#define AN0                               0x0E    // A0
#define AN0_VREF_VREF                     0x0F    // A0 VRefh=A3 VRefl=A2
#define ANALOG_RA3_REF         0x1         //!old only provided for compatibility
#define RA0_RA1_RA3_ANALOG     0x4         //!old only provided for compatibility
#define RA0_RA1_ANALOG_RA3_REF 0x5         //!old only provided for compatibility
#define ANALOG_RA3_RA2_REF              0x8   //!old only provided for compatibility
#define RA0_RA1_ANALOG_RA3_RA2_REF      0xD   //!old only provided for compatibility
#define RA0_ANALOG                      0xE   //!old only provided for compatibility
#define RA0_ANALOG_RA3_RA2_REF          0xF   //!old only provided for compatibility
That means I'm not able to set just AN4 pin or not.
Thk.
PostPosted: Tue Mar 13, 2018 6:09 pm     Reply with quote
That's correct. You can't do it with that PIC.
I suggest you switch to the 16F1847 which can use individual pins for A/D.
However, it requires a Pickit3, ICD3 or higher to program it.
sorasit46
PostPosted: Tue Mar 13, 2018 6:40 pm     Reply with quote
Thank you
PostPosted: Wed Mar 14, 2018 2:07 am     Reply with quote
and (of course), understand that this is not something that CCS are forcing, it is dependant on the capabilities of the PIC itself. This is why we repeat 'read the data sheet'....
