carllw
Lock Door System |
Posted: Fri Mar 02, 2018 4:45 pm |
Hi, I want to do lock door system. I used 16f877a and 4*3 keypad. It work on proteus well but I created circuit on board and i wrote ccs c code for project.
When i enter the key it says key is wrong even if i enter right key. I tried 10 times but it says right key 2 or 3 times. For example i push a number but it doesn't take it sometimes, sometimes take after pushed number etc. I think delays were problem but i didn't find problem. Should I push number fastly or slowly? I don't understand problem. Can anyone help me ?
Thanks.
Code: | #include <16F877A.h>
#FUSES NOWDT
#FUSES NOBROWNOUT
#FUSES NOLVP
#use delay(crystal=4000000)
#define LCD_RS_PIN PIN_B7
#define LCD_RW_PIN PIN_B6
#define LCD_ENABLE_PIN PIN_B5
#define LCD_DATA4 PIN_B4
#define LCD_DATA5 PIN_B3
#define LCD_DATA6 PIN_B2
#define LCD_DATA7 PIN_B1
#include "lcd.c"
#define sut1 pin_d0
#define sut2 pin_d1
#define sut3 pin_d2
#define sut4 pin_d3
#define sat1 pin_d4
#define sat2 pin_d5
#define sat3 pin_d6
#define sat4 pin_d7
#define ROLE pin_c0
char tus=0;
int basildi;
int sifre[4];
char keypad_oku()
output_d(0x00);
tus = "";
output_high(sat1);
if (input(sut1))
{ delay_ms(500); tus=1;basildi=1; }
if (input(sut2))
{ delay_ms(500); tus=2;basildi=1; }
if (input(sut3))
{ delay_ms(500); tus=3;basildi=1; }
if (input(sut4))
{ delay_ms(500); tus=0xA;basildi=1; }
output_low(sat1);
output_high(sat2);
if (input(sut1))
{ delay_ms(500); tus=4;basildi=1;}
if (input(sut2))
{ delay_ms(500); tus=5;basildi=1; }
if (input(sut3))
{ delay_ms(500); tus=6;basildi=1; }
if (input(sut4))
{ delay_ms(500); tus=0xB;basildi=1; }
output_low(sat2);
output_high(sat3);
if (input(sut1))
{ delay_ms(500); tus=7;basildi=1; }
if (input(sut2))
{ delay_ms(500); tus=8;basildi=1; }
if (input(sut3))
{ delay_ms(500); tus=9;basildi=1; }
if (input(sut4))
{delay_ms(500); tus=0x0C;basildi=1; }
output_low(sat3);
output_high(sat4);
if (input(sut1))
{ delay_ms(500); tus=0xE;basildi=1; }
if (input(sut2))
{ delay_ms(500); tus=0;basildi=1; }
if (input(sut3))
{ delay_ms(500); tus=0xF;basildi=1; }
if (input(sut4))
{delay_ms(500); tus=0xD;basildi=1; }
output_low(sat4);
return tus;
void main ( )
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
set_tris_d(0x0F);
lcd_init();
printf(lcd_putc,"\fLock Door");
printf(lcd_putc,"\nV1.0");
delay_ms(1500);
printf(lcd_putc,"\fEnter Key");
// Our system's Key
sifre[0] = 1;
sifre[1] = 9;
sifre[2] = 8;
sifre[3] = 7;
int sec=0;
int yanlis = 0;
int gelen;
gelen = keypad_oku();
if (basildi==1) {
basildi=0;
lcd_gotoxy(7+sec,2);
printf(lcd_putc,"*");
if (sifre[sec] != gelen)
yanlis=1;
sec++;
if (sifre[sec] == gelen)
sec++;
if (sec>3) {
if (yanlis==0) {
printf(lcd_putc,"\fRight Key");
Output_high(ROLE);
delay_ms(2000);
Output_low(ROLE);
printf(lcd_putc,"\fEnter key");
else {
printf(lcd_putc,"\fWrong Key");
lcd_gotoxy(15,2);
delay_ms(1500);
yanlis=0;
sec=0;
Posted: Fri Mar 02, 2018 7:23 pm |
You need to look at the CCS example keypad program as well as the 'flex_kbd' program, maybe google 'scanning keypad algorithm'.
You need to understand that the keypad is a collection of mechnical switches and each switch requires 'debounce'. If you have access to an oscilloscope, connect it to a switch and observe the waveform when you press and release the button. You will NOT see nice square edged 0-1-0 transitions. That's why you need to add 'debounce'. A term used to describe the action to 'clean up' or change that noisey 0-1-0 transition into a clean, fast 'square wave'.
Debounce can be done with hardware (typically selected values of Rs and Cs, chips), software (calculated time delays, timed loops) or a combination of both.
I do suggest, if you intend to pursue electronics as a hobby, especially PICs or 'microcomputers', that you purchase an oscilloscope. Even a 20MHz, 2 channel, CRT type will be of great benefit to you.
Jay |
