HARSHAL KHAJONE
Problem with LIN communication |
Posted: Fri Feb 16, 2018 9:24 am |
Below are my code which I changed for PIC18f46k22 using PIC16F690 code in ccs example
Code: | //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
LIN BUS Master
#include <18f46k22.h>
#FUSES HSM //High speed Osc (> 4mhz)
#FUSES NOPROTECT //Code protected from reads
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOXINST //Extended set extension and Indexed Addressing mode enabled
#FUSES NOPLLEN
#use delay(clock=8000000)
#use rs232(uart1, baud=9600, PARITY=N, Xmit=Pin_C6, RCV=Pin_C7, ERRORS)
#include "LINBUS1.h"
int i,msg_length, id_byte, addr, temp;
int16 adc_val;
int data[8];
int slave_addr = SLAVE_ADDRESS;
int8 command[2]={0xCC,0xA1}; // This command is not of much significanceA1
msg_length = 8; // NOTE - Message Length can only be 2,4 or 8 bytes long
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
delay_ms(300);
output_low(MCP201_CS);
delay_ms(2);// Toggle the CS pin at least 1 ms after wake-up
output_high(MCP201_CS);
delay_ms(200);
setup_uart(UART_SEND_BREAK); //This sends a break character (zero for 12 bit time)
temp=getc(); // Do a read after each write to clear RCREG
// Send Dummy character - Automatically gets set to zero
// putc(0x00); // The later version(4.???) of the compiler will send a putc automatically after UART_SEND_BREAK command
// not required in new version of software
// delay_ms(3);
linbus_generate_synchfield(); // Send Sync Character immediately after break
delay_ms(10); // Set delay - Allow slaves to respond
// Initialize the message length
msg_length =2;
// Send command to slave to read ADC
//The following function Calculates the ID byte, and
// transmits the data, followed by the checksum
Lin_bus_transmit_data(MASTER_ADDRESS, msg_length, &COMMAND[0]);
delay_ms(5); // wait for slave to complete task
// Perform read routine
// Clear Read Interrupt
// clear_interrupt(INT_RDA);
id_byte = read_ident_byte();
msg_length = get_message_length(id_byte);
Errorflag =0; // Reset Error flag
Check_parity_bits(id_byte);
addr = address_match(id_byte);
if(addr == MASTER_ADDRESS)
read_data_packet(&data[0], msg_length);
linbus_verify_checksum(&data[0],msg_length);
// Use Pin D6 and D7 to display the received data
#use rs232(uart2, baud=9600, Xmit=Pin_D6, RCV=Pin_D7,ERRORS)
if(Errorflag!=0)
putc(Errorflag);
delay_ms(5);
adc_val = make16(data[1],data[0]);
printf("\n\r ADC Value Slave - %lu",adc_val);
#use rs232(uart1, baud=9600, Xmit=Pin_C6, RCV=Pin_C7,ERRORS)
LIN Bus Slave
#include <18f46K22.h> //16F690.h
#FUSES NOPLLEN
#device ADC=10
#use rs232(baud=9600,UART1, PARITY=N, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include"LINBUS1.h"
// Function Prototypes
void Transmit_adc_value();
int8 id_byte, msg_length, addr, SPBRG1_temp, temp;
int8 data[8];
setup_adc(ADC_OFF);
delay_ms(300);
delay_ms(2); // Toggle the CS pin at least 1 ms after wake-up
wait_for_master();
delay_ms(10);
//Desired Baud rate range - 1200 baud - 19200
// if((SPBRG < 5)|| (SPBRG>104))
// wait_for_master();
// Work-around for Errata
SPBRG1= SPBRG1-1; // Subtract 1 to get correct Baud Rate- Refer Errata sheet //SPBRG= SPBRG-1
SPBRG1_temp = SPBRG1; // Read SPBRG and write back to SPBRG (see errata) //SPBRG_temp = SPBRG;
SPBRG1 = SPBRG1_temp; //SPBRG = SPBRG_temp;
TXEN = 1; // Set the TXEN bit to enable the transmitter (See Errata)
Errorflag =0; // Reset Error Flag
if (Errorflag==0)
if(addr== SLAVE_ADDRESS || addr==MASTER_ADDRESS)
if(addr==MASTER_ADDRESS)
delay_ms(5); // not required
temp=getc();
break; // If Address match does not occur, RESET states
else // DEBUG Pulse on RC5
output_high(Pin_C5);
delay_ms(1);
output_low(Pin_C5);
//This function will read 10 bit ADC value from AN0 and transmit it to Master
int16 adc_val;
int8 reply[2];
int8 msg_length = 2; // Length of Response
// Init
reply[0]=0;
reply[1]=0;
// ADC ports initialization
setup_port_a(ALL_ANALOG);
setup_adc(adc_clock_internal);
set_adc_channel(0);
delay_ms(1);
adc_val = read_adc();
reply[0] = make8(adc_val,0);
reply[1] = make8(adc_val,1);
reply[1]= reply[1] & 0x03; // set to 10 bit output
delay_ms(4);
setup_port_a(NO_ANALOGS);
setup_adc(ADC_OFF);
make_all_pins_digital();
// Transmit the acquired data over LIN bus
Lin_bus_transmit_data(MASTER_ADDRESS, msg_length, &reply[0]);
LIN bus driver
#define SLAVE_ADDRESS 0x05
#define MASTER_ADDRESS 0X00
// CS/WAKE Pin for MCP201
#define MCP201_CS Pin_C4
// Slave Definitions for Error Flags
byte Errorflag;
#bit ID_Parity_error = Errorflag.0
#bit bit_error = Errorflag.1
#bit CRC_error = Errorflag.2
#bit data_received = Errorflag.3
#bit addr_match = Errorflag.4
// Special Function Registers
#byte BAUDCON1 = 0x9B //BAUDCTL= 0x9B
#bit WUE = BAUDCON1.1
#bit RCIDL = BAUDCON1.6
#byte PIR1 = 0x0C
#bit RC1IF = PIR1.5 //RCIF
#byte SPBRG1 = 0x99 //SPBRG
#byte SPBRGH1 = 0x9A //SPBRGH
#byte TXSTA1 = 0x98 //TXSTA
#byte RCREG1 = 0xFAE //RCREG=0x1A (0x1A is a Address of RCREG)FAE
#bit TXEN = TXSTA1.5
//Function Prototypes//
void linbus_generate_synchfield();
void wait_for_master();
int read_ident_byte();
void Check_parity_bits(int ident_byte);
int address_match(int8 ident_byte);
void read_data_packet(int ident_byte, int *ptr, int msg_length);
int8 linbus_calculate_checksum(byte* databytes, int8 message_length);
int8 linbus_calculate_ident_field(int8 device_address, int8 message_length);
int8 linbus_calculate_ident_parity(int8 ident_byte);
int get_message_length(int id_byte);
void Lin_bus_transmit_data(int device_addr, int msg_length, int8* ptr);
void output_debug(void);
// Macro for Chip Select - for MCP201 chip, CS connected to Pin_C3
#define Chip_SelectMCP201() output_float(MCP201_CS)
#define Disable_MCP201(x) bit_clear(*(x/8+0x80),x%8)
This function will transmit a Sync Character 'U' after a SYNC break
PARAMS: none
RETURNS: none
putc(0x55);
This functions puts the Slave receiver in Wake-Up on RDA mode
and the receiver is setup to auto detect the baud rate
PARAMS: none
RETURNS: none
int garbage;
setup_uart(UART_WAKEUP_ON_RDA);
SPBRG1 = 0; // Clear the baud rate gen register - Errata//SPBRG
SPBRGH1 = 0; //SPBRGH
TXEN = 0; //Clear the TXEN bit to disable the transmitter - Errata
RC1IF=0; //RCIF
while(!RC1IF); //while(!RCIF);
WUE=0; // Manually clear the WUE bit - Errata
garbage = getc(); //RCIF is cleared with a read of RCREG
setup_uart(UART_AUTODETECT_NOWAIT); // Auto Detect the baud rate
while(!RC1IF); // Verify baud rate was measured - RCIF set from byte received //while(!RCIF);
garbage=getc();
This function is called after wait_for_master() to read the ID byte
PARAMS: none
RETURNS: ID byte
int id_byte;
id_byte = getc();
return(id_byte);
This function verifies the parity bits of the received ID byte
and sets the errorflag if error is present
PARAMS: none
RETURNS: none
int parity, temp_parity;
parity = ident_byte & 0xC0;
temp_parity = ( ( (ident_byte >> 0) ^ (ident_byte >> 1) ^ (ident_byte >> 2)
^ (ident_byte >> 4) ) & 0x01 ) << 6 ; // parity bit6
temp_parity |= ( ( (ident_byte >> 1) ^ (ident_byte >> 3) ^ (ident_byte >> 4)
^ (ident_byte >> 5) ) & 0x01 ) << 7; // parity bit 7
if(temp_parity == parity)
ID_Parity_error =0; // Reset Parity Error
ID_Parity_error =0; // Set Parity Error
The receiver checks the ID byte bits 0-3 for a address match
PARAMS: none
RETURNS: addr
int addr;
addr = ident_byte & 0x0F;
if (addr==MASTER_ADDRESS || addr==SLAVE_ADDRESS) // slave_addr is defined at top of header file
addr_match=0;
addr_match =1;
return(addr);
void read_data_packet(int *ptr, int msg_length)
This function will read the data packet
PARAMS *ptr: Address where data will get stored
PARAMS msg_length: Length of the message
RETURNS: none
int i; // This is the number of bytes of data - 2,4 or 8
data_received =1;
for(i=0;i<msg_length;i++)
*ptr =getc();
ptr++;
if(i== (msg_length-1)) // Set the data received bit
data_received=0; // once reception is complete
int8 linbus_calculate_checksum (byte* databytes, int8 message_length)
This function will calculate checksum for received data
PARAMS databytes: The received data bytes
PARAMS message_length: Length of message
RETURNS: 8 bit inverted module -255 checksum
int8 i;
int8 sum;
sum = 0;
for (i=0; i<message_length; i++)
sum += databytes[i];
sum = 0-sum;
return sum;
int8 linbus_calculate_ident_field(int8 device_address, int8 message_length )
This function will assemble the ID byte from the address and data length
PARAMS device_address: address of the device
RETURNS: Assembled ID byte
int8 ident_byte;
if(message_length==8)
message_length=0x03;
else if(message_length==4)
message_length=0x02;
else if(message_length==2)
message_length=0x01;
ident_byte = (device_address & 0x0F) | ((message_length & 0x03)<<4);
ident_byte |= linbus_calculate_ident_parity (ident_byte);
return ident_byte;
int8 linbus_calculate_ident_parity(int8 ident_byte )
This function calculates the ident field parity according to specification
The parity is returned in bit 7 and 6 according the specification, all other bits are unset
this parity should be checked even in the receiver
PARAMS ident_byte: The ID byte containing 6 bits of information (0-5)
RETURNS: Parity inserted into the ID byte (Final ID byte)
int8 parity;
^ (ident_byte >> 5) ) & 0x01 ) << 7 ; // parity bit 7
return parity;
void linbus_verify_checksum(byte* databytes, int8 message_length)
This function will verify the checksum of the data received
Call this function after read_data_packet()
PARAMS databytes: Received Data
RETURNS: none
This function will set the CRC_error bit in Errorflag if it detect checksum error
int CRC, CRC_actual;
CRC_actual = getc();
CRC = linbus_calculate_checksum(&databytes[0], message_length);
if(CRC_actual==CRC)
CRC_error =0;
CRC_error =0;
This function will extract Message Length from the ID Byte
PARAMS id_byte: The ID byte
RETURNS msg_length: The message length
int ident_byte, msg_length;
ident_byte = ((id_byte&0x30)>>4);
if(ident_byte==0||ident_byte==1)
msg_length =2;
if(ident_byte==2)
msg_length =4;
if(ident_byte==3)
msg_length=8;
return(msg_length);
PARAMS device_addr: address of device
PARAMS msg_length: Length of message
PARAMS ptr: Data to be transmitted
RETURNS: none
int id_byte, CRC,i, temp;
id_byte = linbus_calculate_ident_field(device_addr, msg_length);
putc(id_byte); // Put the ID byte on the Line
delay_ms(5);
putc(ptr[i]); // Put the Data bytes on the Line
delay_ms(5);
// calculate the CRC of the Data to be transmitted
CRC = linbus_calculate_checksum(&ptr[0], msg_length);
putc(CRC); // // Put the CRC byte on the Line
temp=getc(); // Do a read afvter each write to clear RCREG
delay_us(50);
output_low(Pin_C5);
Posted: Fri Feb 16, 2018 11:51 am |
from the LIN driver....
#byte PIR1 = 0x0C
that's NOT the PIR1 for an 18F46K22 according to my datasheet copy...
maybe others can confirm but I'm guessing that's part of your problem.
I didn't check any others but registers for that PIC are 3 characters long, usually 0xFxx .....
Hopefully you still have original LIN driver to copy THEN edit the NEW version !
This is one reason why I suggested the 'try 690 PICs, then 46 master then 46 slave....even just ONE incorrect variable or register and it won't work.
Jay |
Posted: Fri Feb 16, 2018 11:52 am |
Most of these register addresses are wrong for the 18F46K22. Most
of them are for the 16F690.
#byte PIR1 = 0x0C
#bit TXEN = TXSTA1.5 |
You can fix these errors by using getenv() to get the register addresses
instead of hard-coding them. Example:
Code: | #byte PIR1 = getenv("SFR:PIR1") |
The #bit statements are correct. You don't have to change them.
Just fix the #byte statements. |
HARSHAL KHAJONE
Posted: Fri Feb 16, 2018 10:36 pm |
temtronic wrote: | from the LIN driver....
#byte PIR1 = 0x0C
Thanks a lot temtronic, after changing correction as you say and other register address code get run successfully
Thanks again for your support, keep supporting me i'm newer in PIC
Last edited by HARSHAL KHAJONE on Fri Feb 16, 2018 10:42 pm; edited 1 time in total |
HARSHAL KHAJONE
Posted: Fri Feb 16, 2018 10:41 pm |
PCM programmer wrote: | Most of these register addresses are wrong for the 18F46K22. Most
#byte PIR1 = 0x0C
Thank you PCM programmer for your support, the fault was address of register that is solve ![Smile](images/smiles/icon_smile.gif) |
