PIC18F4620 slow clock problem
Linxroot
PostPosted: Wed Jan 24, 2018 6:24 am     Reply with quote
In my project the PIC18F4620, with 10MHZ crystal result in 312KHz in
while loop. Should not it be: 10MHz crystal div/4 (in the PIC internal divider)= 2.5Mhz?
CCS PCH C Compiler, Version 5.015, xxxx
I did a test code to show the problem:
#include <18F4620.h>
#device ADC=16
#FUSES NOLVP
#FUSES NOXINST
#FUSES NOFCMEN
#FUSES NOIESO
#FUSES HS
#use delay(crystal=10000000)
   while(true)
      output_toggle(PIN_D5);
The LST file:
.................... #device PIC18F4620
.................... #list
.................... #device ADC=16
.................... #FUSES NOWDT                    //No Watch Dog Timer
.................... #FUSES NOBROWNOUT               //No brownout reset
.................... #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
.................... #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
.................... #FUSES NOFCMEN
.................... #FUSES NOIESO
.................... #FUSES HS
.................... #use delay(crystal=10000000)
.................... void main()
00004:  CLRF   FF8
00006:  BCF    FD0.7
00008:  MOVF   FC1,W
0000A:  ANDLW  C0
0000C:  IORLW  0F
0000E:  MOVWF  FC1
00010:  MOVLW  07
00012:  MOVWF  FB4
....................    while(true)
....................       output_toggle(PIN_D5);
00014:  BCF    F95.5
00016:  BTG    F8C.5
00018:  BRA    0014
0001A:  SLEEP
Configuration Fuses:
   Word  1: 0200   HS NOFCMEN NOIESO
   Word  2: 1E18   PUT NOBROWNOUT BORV21 NOWDT WDT32768
   Word  3: 8700   CCP2C1 PBADEN LPT1OSC MCLR
   Word  4: 0081   STVREN NOLVP NOXINST NODEBUG
   Word  5: C00F   NOPROTECT NOCPB NOCPD
   Word  6: E00F   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 400F   NOEBTR NOEBTRB
The result in scope:
[img]https://drive.google.com/file/d/18mpdubaDCJvmaJp9wP1ky3049EDvTaiY/view?usp=sharing[/img]
Would be an oscillator configuration problem?
PostPosted: Wed Jan 24, 2018 6:48 am     Reply with quote
what caps are you using for the xtal?
does another xtal work
can you scope the xtal pin to confirm it's oscillating ?
does the PIC run on internal ?
Linxroot
PostPosted: Wed Jan 24, 2018 7:06 am     Reply with quote
I'm using 15 pF caps
I used 10Mhz resonator too and the result is the same
I tested the xtal pin in the scope and it run at 10Mhz (very stable)
with these settings, it should be external clock, but really, the resulting frequency seems to be of the internal oscillator.
gaugeguy
PostPosted: Wed Jan 24, 2018 7:29 am     Reply with quote
10MHz crystal
/4 for internal instruction
/4 for number of instructions in loop
/2 for complete cycle (one loop high & one loop low)
10M /4 /4 /2 = 312.5k
RF_Developer
Re: PIC18F4620 slow clock problem
PostPosted: Wed Jan 24, 2018 7:35 am     Reply with quote
In a word, no. While there is only one C statement in the loop, there is more than one instruction: two to do the output and one (braches are two cycle instructions I beleive) to do the loop. I'd expect the output to be 10MHz/4/4 (instructions)/2 (as the loop toggles and one cycle of the output is two loops) = 312.5KHz, which is what you report. Therefore it's working perfectly. Granted its not working as you expect, but it is working as is should.
No, actually its an unrealistic expectation problem.
PS: Cross-posted with Gaugeguy who says the same thing.
Linxroot
PostPosted: Wed Jan 24, 2018 9:29 am     Reply with quote
Hmmm, it's true! Thank you very much for the quick response.
