		| Author | Message |
		| B3RT86
				| Error#112  Function used but not defined:  ... delay_ms 446 |
				|  Posted: Tue Jan 23, 2018 10:37 am |   |
				| Hello, I introduce myself. My name is Alberto. I'm a spanish mechatronics engineer and I guess I must be driving myself insane.
 First of all excuse my english. I'm learning too :-)
 I am trying to debug a program in a PIC16F887 with MPLAB IDE X by CCS.
 I've added the 16f887.h file to the project/header_files and I've added too the LCD driver to the object files. The main program is in the Source folder. Well.
 I included the header file in the  *.c docs but  the compiler doesn't recognize the function delay_ms in the LCD driver but there isn't problems in the main file with this delay.
 MAIN.C
  	  | Code: |  	  | #include <16F887.h>
 #use delay (clock=4000000)
 #include "LCD_pc1602f.c"
 #use fast_io(A)
 #use fast_io(B)
 #fuses INTRC,NOWDT,PUT,BROWNOUT,NOPROTECT,NOLVP,NOCPD,NOWRT
 What can I try?
		| B3RT86
				| Error#128  A #DEVICE required before this line |
				|  Posted: Tue Jan 23, 2018 10:56 am |   |
				| If I don´t #include the header file in the LCD driver.c. I get this error Error#128  A #DEVICE required before this line. I choose my device in the header file. I don´t know what´s wrong :'-|
		| PCM programmer
		| B3RT86
				|  Posted: Tue Jan 23, 2018 12:16 pm |   |
				| Yes, thx. i read it months ago, I hadn't had problems in the others projects but now it become insane. |  |
		| PCM programmer
				|  Posted: Tue Jan 23, 2018 12:24 pm |   |
				| But you are doing weird stuff like this:
  	  | Quote: |  	  | I've added too the LCD driver to the object files |
 CCS has a way to link object files.  It's called Multiple Compilation Units.
 But it's only available with the CCS IDE version of the compiler.
 Using MPLAB-X, you don't use object files.  Don't add them to any folder
 in MPLAB-X.  Only use source .c files.
 Also, don't add lcd driver files to any folder in the MPLAB-X project
 window.  Just have an #include line for the lcd source file in your
 main C source file.
 Also, don't add the 16F887.h file to every driver file that you have.
 There should only be an #include line for 16F887.h at the start of your
 main C source file.
 Don't start randomly adding files to various MPLAB-X folders.  Just have
 your main C source file in the "Source files" folder in the MPLAB-X project
 window.   Don't put anything in "Header files".
		| B3RT86
				| BUILD SUCCESSFUL |
				|  Posted: Tue Jan 23, 2018 1:05 pm |   |
				|    At first I only agree the Header file and the LCD driver just as i learned. The weird things came when it didn't work like that and i started to try ways
 Thank you so much!!
