can_putd
g@rd3n3r
can_putd
PostPosted: Tue Nov 14, 2017 2:56 pm     Reply with quote
revisiting after a long haitus.
can_putd(int32 id, int * data, int len,int priority, int1 ext, int1 rtr);
question about priority. The lower the value the higher the priority the message will be, right?
PostPosted: Tue Nov 14, 2017 3:39 pm     Reply with quote
No. The message with the _lowest_ priority is postponed in the event of a conflict.
Read the comments in the driver itself:
// priority - priority of message. The higher the number, the
// sooner the CAN peripheral will send the message.
// Numbers 0 through 3 are valid.
0 to 3 only. 3 is the highest priority, 0 the lowest.
This is standard on CAN itself.
newguy
PostPosted: Tue Nov 14, 2017 4:42 pm     Reply with quote
As Ttelmah has said, this is an internal (to the CAN peripheral) priority which is used to determine which message (if more than one), gets routed to the TX circuitry when a transmit slot opens up on the CAN bus.
For things like J1939 and/or NMEA 2000, you're correct in that the priority there corresponds to the first 3 bits transmitted on the CAN bus, and in that instance, the number of dominant/recessive bits determines who "wins" if more than one device attempt to simultaneously transmit on the bus.
