how setup_ports() for RA2 to REF- and RA3 to REF+ PIC16F88
artohautala
PostPosted: Mon Nov 13, 2017 8:44 am     Reply with quote
I'm trying to setup analog port RA0 to measure analog signal betveen 2...3
V instead of 'normal' 0...5V...
...because that way I can get 1023 steps for 1V instead of getting if I use
5V reference I get only 1023/5 steps ... about 205 steps when using 10 bit
AD-conversion ...
... but is it possible to define REF- pin RA2 to be 2V and pin RA3 to be 3V
so I can get 2...3 V ... 2V = AD-result 0 and 3v is AD-result 1023 ?
Please advise me ... I'll be very pleased if you will.
Best regards for you all
Smile
is this OK:
setup_adc_ports(sAN2 | VREF_VREF | VREF_LOW);
  setup_adc_ports(sAN3 | VREF_VREF | VREF_HIGH);
-arto-
PostPosted: Mon Nov 13, 2017 8:56 am     Reply with quote
It is possible to apply 2v to RA2, and 3V to RA3, and set the ADC to use these as it's reference. Needs you to have an accurate voltage source to do this.
However, won't work.
There is a minimum voltage span for the ADC. Data sheet for your chip. Try to operate below this, and monotonicity of the ADC is no longer guaranteed. Vref (min). 2.2v (rising to 2.5v for the full temperature range).
You need to amplify your signal.
artohautala
PostPosted: Mon Nov 13, 2017 9:29 am     Reply with quote
Thanks Ttelmah for your very professional knowledge,
and get better way.
So I have 5V reference ic REF02 and I use that for PIC REF+ to RA3 and REF- is GND and I use opamp (LMC662 rail to rail opamp) to be as differential amplifier.
So I can convert 2...3V to 0...5V for getting 10 bits AD-result 0...1023.
Did I understood right ?
Thank you and all the best.
-arto-
PostPosted: Mon Nov 13, 2017 11:16 am     Reply with quote
Yes. Smile
PostPosted: Mon Nov 13, 2017 11:28 am     Reply with quote
also...
be sure to use real good filtering of the opamp power supply as well as inputs. ANY 'ripple' WILL get read by the ADC.
Digital is easy...analog is 'fun'
JAy
