languer Guest
| CCS vs PBP Suggestions |
Posted: Fri Jan 09, 2004 10:14 pm |
I am currently considering acquiring either of these programs. Would somebody with experience in both languages care to comment
TIA,
languer. |
dazlogan
Joined: 19 Oct 2003 Posts: 24 Location: Cambridge, UK
| hello |
Posted: Thu Jan 15, 2004 6:21 pm |
I used PBP for about 5 years, it served its purpose well and has helped make some very successful products.
I moved over to C about 2 years ago for a few reasons.
1. To standardise on our embedded programming language at work (the concensus was that C was an all round better language to use than BASIC)
2. PIC C offers you more.
PBP does not support floating point and 32 bit variables.
PBP interrupt handling is crude.
PBP (or BASIC in general) is not as easy to read.
and so on...
However, I must say that I never found a single bug with PBP. I have come across some very frustrating bugs in PIC C... sure i've been able to sort them but could have done without them.
Depends on what you want to do and your personal preferences.
My advice would be to choose C, in the end you will become a more competant programmer in my opinion and will have a lot more power at your finger tips.
Saying the above, no language will EVER beat Visual Basic!
Regards,
Darren |
Posted: Thu Jan 15, 2004 7:02 pm |
Hi...
My company is on embedded systems and we are using both C & Basic as the language of choice but the consensus of all engineer in the company is that we are going to use C-language as our preferences since portable to any microcontroller system like PIC, AVR, ATMEL, and the rest....
With this the group decided to use CCS C-compiler for the development. Based on my experience in using CCS well it provides the need for our embedded application so far. I agree that their are bugs on this CCS thing.
One good thing... if u encounter problem just visit this forum/community for comments or write to CCS support.
Hope this gives you insight...
Choose wisely.... |
languer
Posted: Fri Jan 16, 2004 5:40 pm |
To Darren and 'guest':
Thanks for your replies. After talking with some colleagues, reading your replies, and some unfortunate event trying to upgrade from PBC to PBP I have decided to purchase from CCS.
I have never programmed in C, but have done so in Java and Assembly (and of course VB). After some extensive examinations of available examples and the like, I do not think it will be too much of a challenge.
Again, thanks for your valuable inputs.
languer. |
