Pic16F628 problem when Oscilloscope disconnected
Stanley
PostPosted: Fri Jan 09, 2004 2:27 pm     Reply with quote
Hi.
Have a strange problem whit my Pic16F628 communicating on 9600 8N1 whit a mobile phone running at 3.6V.
When I have the oscilloscope connected to the clock out everything is working find but when I disconnect the scope I only receve garbage from the phone. Anyone know what could be wrong??
Settings:
#fuses NOWDT,INTRC, PUT, PROTECT, NOBROWNOUT, MCLR, NOLVP, NOCPD
#use rs232(baud=9600,xmit=PIN_B6,rcv=PIN_B7, stream=PHONE) // For communication to phone. Use Software
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
Adrianf
Re. Pic16F628 problem when Oscilloscope disconnected
PostPosted: Fri Jan 09, 2004 2:56 pm     Reply with quote
Just a guess but mobiles give off a fair bit of RF. Have you tried a capacitor of a similar value to the scope probe on the same pin to ground? Might give you a pointer. I've had circuits do similar where the scope has damped out oscillations.
PostPosted: Fri Jan 09, 2004 3:17 pm     Reply with quote
My first thought was a missing ground connection or the MCLR
pin was left unconnected. Upon researching it, I found this
post at Microchip, which yes, does end up being a messed up
MCLR circuit. Check that first.
http://forum.microchip.com/tm.asp?m=18330
Stanley
PostPosted: Mon Jan 12, 2004 4:06 am     Reply with quote
Thanks for the replay.
I found out that my scope have an input at 1Mohm and 22pf Smile
-Stan.
