jujoab
How to open ide preferences in order to configure IDE |
Posted: Tue Sep 19, 2017 10:20 pm |
I am searching for hours on this forum trying to find the way to have code completion or code assist working.
One note I found says to open the preferences tab but I can't find it.
Thanks in advance.
juan abba |
Posted: Wed Sep 20, 2017 12:57 am |
Options.
IDE
Are you sure are looking at documentation for Custom Computer Services?.
Unfortunately a lot of web searches on 'CCS', instead find stuff relating to Ti Code Composer Studio (which is also abbreviated as 'CCS').
A reference to 'preferences', makes me think you are looking at 'webwork' for the Ti IDE, not the Custom Computer Services IDE...
Custom Computer Services C, doesn't have a 'code assist' option. Code completion is normally on by default.
CCS (here), predates Ti using the same initials, so 'blame Ti' for electing to use the same name.... |
jujoab
Posted: Wed Sep 20, 2017 7:13 am |
Thanks Ttelmah.
I assumed that they were the same ( ti and pic ) CCS c.
Pls let me ask for an extra piece of help.
My code completion did work OK, but now is not showing any completion when ctrl + space is pressed.
Just in case I reinstalled the 074, but still not working.
Is there anywhere on the IDE configuration the may affect code completion ???? |
jujoab
Posted: Wed Sep 20, 2017 2:55 pm |
Hi
I found the configuration windows were "USE CODE COMPLETE" could be selected.
OPTIONS-->>IDE-->>GENERAL-->>EDITOR options.
It was selected on my case, but as explained on previous note it was not working.
I deselected and selected again with no expected results.
Them I proceed with a complete deinstallation, even cleaning PICC folder and installed again.
Problem remains. CTRL + space do not produce any results.
Thanks in advance.
juan |
Posted: Wed Sep 20, 2017 7:02 pm |
On the versions page they say:
Quote: | 5.074 Fixed an issue where code completion in the IDE would replace too much text. |
Maybe they broke it instead.
If you own the compiler and paid for it, then contact CCS support.
Their email is: support@ccsinfo.com |
jujoab
Posted: Thu Sep 21, 2017 1:56 pm |
There is a trick to get it working.
Tested several PIC's, all ok.
The trick is to create the project, insert a few lines after
#include <xxxxxxxxxx.h> and BUILD it.
After doing the build, the "code completion" will start to work for that project, even with 074.
Thanks for the help.
juan |
