Propblem comparing two strings using rs232
Indira Learner
PostPosted: Sat Sep 09, 2017 3:33 am     Reply with quote
Hello, there is a code i wrote to compare a string received using a communication port. The code worked well a few times, and then it stopped working. I do not know what the error is. It actually compiles without an error, but when i run it, the output is always wrong even if both words match.
#include <main.h>
#include <stdio.h>
#include <string.h>
#fuses HS
#use rs232(uart1, baud=9600)
char password[] = {"123abc"};
char string_pass[];
char input_str[];
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#INT_EXT
void  EXT_isr(void)
   reset_cpu();
#INT_RDA
void  RDA_isr(void)
   int t;
   buffer[next_in] = getc();
   t = next_in;
   next_in =(next_in + 1) % BUFFER_SIZE;
   if(next_in == next_out)
      next_in = t;
BYTE bgetc()
   BYTE c;
   while( ! bkbhit);
   c = buffer[next_out];
   next_out =(next_out + 1) % BUFFER_SIZE;
   return(c);
void my_get_string(char* s)
   unsigned int8 len;
   char c;
   len = 0;
   do
      c = bgetc();// Call bgetc()
      if((c >= ' ')&&(c <= '~'))
         s[len++] = c;
         putc(c);
   while(c != 13);
   s[len] = 0;
void toggle_function()
   int i;
   i=0;
   while(i<20){
      output_high(led1);
      output_low(led1);
      i++;
void compare_function(char *string)
   if(strcmp(string,password) == 0)
      printf("\n Correct Keyword ! \n ");
      toggle_function();
      printf("\n ERROR\n");
   clear_interrupt(INT_EXT);
   enable_interrupts(INT_EXT);
   clear_interrupt(INT_RDA);
   enable_interrupts(INT_RDA);
      printf("Type string here: ");
      my_get_string(input_str);
      strcpy(string_pass,input_str);
      compare_function(string_pass);
PostPosted: Sat Sep 09, 2017 9:55 am     Reply with quote
char string_pass[];
char input_str[];
Give these two arrays a size. Without the size, you don't have arrays.
You just have a pointers, and they will overwrite other RAM values
if you write to the "array".
Give each array a useful size, big enough so that it will hold the entire
expected string, and maybe some more bytes as a precaution.
Make sure you make the arrays big enough to have the 0x00 byte
that marks the end of every string.
