Improper display segments
POPE19
PostPosted: Wed Sep 06, 2017 10:28 am     Reply with quote
I am using PIC16F1939 to interface 7 segment LCD (3 digits). I have interfaced the LCD with the pic using the Internal register Ladder. I am observing the strange problem.
When i manually change counts for digits 1,2,3 then everything is displayed as input inserted, but when i put count=11 (which is null) the lcd displays erratic segments instead of turning all segments off.
Any suggestions as to why this is happening.
#include <16F1939.h>
#fuses HS ,NOVCAP, MCLR, NOWDT, PUT, NOIESO, BROWNOUT, NOFCMEN,PLL_SW,WRT,CPD
#use delay(crystal=20MHz, clock=20MHz)
//                                 LCD Configuration                                                  |
// Digit segments  A           B         C          D           E         F         G          DP
//                 b7          b6        b5         b4          b3        b2        b1         b0
#define DIGIT3  COM0+11,   COM1+11,   COM2+11,   COM3+11,   COM2+10,   COM0+10,   COM1+10,   COM3+10
#define DIGIT2  COM0+17,   COM1+17,   COM2+17,   COM3+17,   COM2+18,   COM0+18,   COM1+18,   COM3+18
#define DIGIT1  COM0+19,   COM1+19,   COM2+19,   COM3+19,   COM2+20,   COM0+20,   COM1+20,   COM3+20
//       ComX+Y is combination of Backplan0-3 and Segment0-SegmentXX
//           character          0    1    2    3    4    5    6    7    8    9  Null
//byte const Digit_Map[11]   = {0xFD,0x61,0xDB,0xF3,0x67,0xB7,0xBF,0xE1,0xFF,0xF7,0x01}; //Decimal
byte const Digit_Map_1[11] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6,0x00}; //no Decimal
//                          Segments Initilization                                                   //
// Seg23 Seg22  ...  Seg12 Seg11 Seg10 Seg9 Seg8 Seg7 Seg6 Seg5 Seg4 Seg3 Seg2 Seg1 Seg0             //
//  0/1   0/1   0/1   0/1   0/1   0/1  0/1  0/1   0/1  0/1 0/1   0/1 0/1  0/1  0/1   0/1             //
//  if bit_SegX is 1, SegX is set as Segment Output. Otherwise                                       //
#define Segments 0x1E0C00        // Initilize LCD SegmentX
int count3 = 0;// after decimal
int count2=0;   // 1st digit
int count1=0;   // 2nd digit
void Display()
   lcd_symbol (Digit_Map_1[count3], DIGIT3);
   lcd_symbol (Digit_Map_1[count2], DIGIT2);
   lcd_symbol (Digit_Map_1[count1], DIGIT1);
       set_tris_a (0xC9); //set RA-0,3,5,6,7 as inputs
       set_tris_b (0xCF);
       set_tris_c (0x80);
       set_tris_d (0x0C);
       set_tris_e (0x08);
       setup_comparator (NC_NC_NC_NC);
       enable_interrupts (INT_TIMER0);
       // set segments, contrast, internal resistor ladder
       setup_lcd(LCD_MUX14|LCD_HALT_IDLE|LCD_FOSC|LCD_VOLTAGE3 |LCD_REF_ENABLED |LCD_REF_VDD|LCD_A_HIGH_POWER |LCD_B_MED_POWER|LCD_A_CLOCK4,3, Segments);
       count1 = 8;
       count2 = 8;
       count3 = 8;
       Display ();
       delay_ms (1000);
       printf("hello started");
       while (TRUE)
            count1=11;
            count2=11;
            count3=11;
            Display();
Using CCS PCWH 5.072 compiler.
PostPosted: Wed Sep 06, 2017 11:16 am     Reply with quote
byte const Digit_Map_1[11] = .....;
count1=11;
count2=11;
count3=11;
Your digit array is declared with 11 elements total.
What index should you use to access the last element in the array ?
POPE19
PostPosted: Wed Sep 06, 2017 11:47 am     Reply with quote
Got it thanks!! Silly mistake Rolling Eyes
