Problem with XT_PLL4 in dspic30f6015
congthinh95
PostPosted: Sun Sep 03, 2017 12:45 am     Reply with quote
I have problem when i use #use delay(clock=40Mhz,crystal=10Mhz).
When i test blink led with delay 1s, it blinks too slow. So can you help me to fix it ? Thank you so much!
Improve dspic more
PostPosted: Sun Sep 03, 2017 3:34 am     Reply with quote
Have you actually proved the crystal is working?.
Post your fuses.
The obvious suspicion is that it doesn't think the crystal is there, and is 'falling back' to the RC oscillator. This can happen if the crystal gain is a little low, and it is not starting. This is why they recommend a resistor is present across the crystal. Typically perhaps 1M5R. This helps ensure the oscillator starts. Later DsPIC's have this built in the die, but the older ones like this don't.
PostPosted: Sun Sep 03, 2017 5:28 am     Reply with quote
Another thought is that , if using MPLAB, the program was compiled in 'debug' mode and not 'release'.
Then to expand Mr. T.s comment.... PCB isn't correct, missing solder or 'extra', wrong xtal, wrong caps,...
Posting the '1Hz LED' program would help, as well as the compiler version and how you stuuf the code into the PIC (ie: IDE and programmer).
Once we know all this, then we can narrow down the reason to be either hardware, software or firmware.
Jay
PostPosted: Sun Sep 03, 2017 9:00 am     Reply with quote
and (of course) compiler version number....
congthinh95
PostPosted: Mon Sep 04, 2017 12:36 pm     Reply with quote
My fuse is
#FUSES XT_PLL4
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES BORRES //Reserved (do not use)
//#fuses noput
#device ICSP=1
#use delay(crystal=10000000,clock=40000000)
Post your fuses.
Improve dspic more
congthinh95
PostPosted: Mon Sep 04, 2017 12:38 pm     Reply with quote
Tks so much, if i use crystal =20Mhz, so what type of Caps i need to use?
Jay
Improve dspic more
congthinh95
PostPosted: Mon Sep 04, 2017 12:39 pm     Reply with quote
I used CCS 5.0.15. :(
Improve dspic more
PostPosted: Mon Sep 04, 2017 1:33 pm     Reply with quote
That's not actually a CCS version number. They are in the format x.xxx
Look at the list file of in the help screen if you have the IDE for the compiler version. What you have there is the version as reported by Windows.
We need the version so we can test with the same compiler version and see what the fuses actually result in. It changes with some assumptions made by different compiler versions.
If it is 5.015, then this is quite an early V5 compiler.
