Reading the dsPIC33EP512GS502 datasheet I found that this device has a "dedicated ADC Module"...
How I can use this module?
Compiler Version 5.074 _________________ Ricardo
Posted: Wed Aug 30, 2017 12:00 am
You need to look at ex_adc_epgs.c
This is the example of using the ADC on this type of chip.
There are several more things that have to be setup, than simply the master clock....
You also need to study the data sheet about which ADC accesses which input pin. You channel selection would be wrong even without the dedicated ADC (AN0 != channel 1....).
RicSToz87
[SOLVED]
Posted: Wed Aug 30, 2017 6:54 am
Thanks, Ttelmah!
Works fine as the example! _________________ Ricardo
