String too long
sergioigel
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
String too long
PostPosted: Fri Aug 25, 2017 8:25 am     Reply with quote
When I try to compile this code, it works:
char frame[90];
strcpy(frame,"123456789_123456789_123456789_123456789_123456789_123456789_123456789_123");
and if I use this code, it does not work:
char frame[90];
strcpy(frame,"123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234");
functions.c:274:16: Error#6 String too long
Somebody help me.
Thank you,
sergio
PostPosted: Fri Aug 25, 2017 8:41 am     Reply with quote
What processor?.
sergioigel
PostPosted: Fri Aug 25, 2017 9:09 am     Reply with quote
Ttelmah wrote:
What processor?.
PIC16F18877
CCS PCM Compiler v5.074
PostPosted: Fri Aug 25, 2017 12:03 pm     Reply with quote
That chip has maximum ram banks of just 80 bytes each. It'll only complain when you actually start to use the RAM.....
Don't try to copy the string to RAM. Use it from ROM.
Declare the string you want as a const, and use
#device PASS_STRINGS=IN_RAM
Not sure it'll do what you want, but it ought to use a small buffer and allow your code to handle the ROM string as if it is in RAM.
Honestly if you want to actually handle single lumps of RAM this long, then it'd be far easier to switch to a PIC18...
sergioigel
PostPosted: Fri Aug 25, 2017 12:57 pm     Reply with quote
I need to use a variable 100 bytes..... do you have a example how make this with this PIC ?
PostPosted: Fri Aug 25, 2017 2:24 pm     Reply with quote
It'll generate the array, and automatically handle page switching to it, but you can't write it as one 'lump' with strcpy.
   char frame[101];
  strcpy(frame,"123456789_123456789_123456789_123456789_123456789_");
   strcpy(frame+50,"123456789_123456789_123456789_123456789_123456789_");
I've made it 101 characters, to allow for the extra null terminator, but overwritten the one put in by the first transfer.
