aaronik19
Port pin does not work on Pic16F88 |
Posted: Wed Aug 16, 2017 1:54 pm |
Dear Friends,
I wrote a program and when I uploaded to the PIC16F88, some outputs did not work. I tried the raw sample program of just blinking LED and noticed that on Port B bit 3 the Led does not blink. why?
I am using PIC16F88, crystal 20MHz.
#include <trial_ebayboard.h>
set_tris_b(0x00);
//Example blinking LED program
while(true)
output_low(PIN_B3);
delay_ms(DELAY);
output_high(PIN_B3);
delay_ms(DELAY);
Than when I try PIN_B7 and PIN_B6 it works fine. Is there something I am missing? Just to let you know that I also tried the same program on proteus and it work correctly. I know that some of you do not agree on Proteus but this might be a clue. |
Posted: Wed Aug 16, 2017 2:02 pm |
You don't show us your fuses.
You almost certainly have LVP enabled. This uses pin B3. |
aaronik19
Posted: Wed Aug 16, 2017 2:04 pm |
this is the fuses:
Code: | #include <16F88.h>
#device ADC=16
#use delay(crystal=20000000)
#define LED PIN_B3
#define DELAY 1000 |
Posted: Wed Aug 16, 2017 2:20 pm |
Quote: | #include <trial_ebayboard.h> |
Post a link to the Ebay page for your board. |
aaronik19
Posted: Wed Aug 16, 2017 2:23 pm |
what ebay link?? |
Posted: Wed Aug 16, 2017 2:31 pm |
Your post has a file called "ebay board". I assume you bought a
development board from ebay. Just an assumption. |
aaronik19
Posted: Wed Aug 16, 2017 2:32 pm |
yes to identify the program. Just a name |
Posted: Wed Aug 16, 2017 3:57 pm |
I wonder if the LVP fuse is really being disabled.
1. Temporarily remove the LED circuit from pin B3.
2. Add a 10K pull-down resistor on pin B3. That's 10K to ground.
3. Program the PIC with the #fuses set to NOLVP.
4. Remove the pull-down resistor and re-connect your LED circuit.
5. Test and see if the LED now blinks properly. |
Posted: Thu Aug 17, 2017 12:41 am |
Let's ask the other question.
What compiler version number please?.
Then we can test and see if this pin is being setup correctly.
There are a sequence of things in order:
1) LVP. Could include things like the board being designed to use LVP, so the pin has a jumper or something to short it low when not being used for programming. Hence the request to see the board involved.
2) A hardware problem with the board. Includes the above, but covers things like solder whiskers etc..
3) A problem with a particular compiler version, or your programmer.
4) Loads of other things...
One thought, from '3' is that you might have your programmer not setup to actually write the configuration fuses. LVP is the default. |
aaronik19
Posted: Thu Aug 17, 2017 12:29 pm |
Dear All,
I am using compiler 5.015 and the programmer is the PICKit2. |
Posted: Thu Aug 17, 2017 1:03 pm |
and what software are you using to control the programmer?.
Look if it has a setting to control whether it writes the configuration words?. |
Joined: 01 Jul 2010 Posts: 9198 Location: Greensville,Ontario
Posted: Thu Aug 17, 2017 1:09 pm |
this....
should have it's contents posted.
Header file contents are unknown to us,even Google came up short!
You should also post a 'link' to the PCB you bought which has to have pinout, specs, schematic, etc.
I've used the PICKit3 to program the 16F88 years ago with no problems but nothing says you couldn't have a hardware issue( ie. solder wisk, open) though I suspect software( incorrect fuses).
aaronik19
Posted: Thu Aug 17, 2017 1:22 pm |
this is the setting in the image below:
aaronik19
Posted: Thu Aug 17, 2017 2:57 pm |
I've just taken the code assembled from what has been posted:
#include <16F88.h>
#device ADC=16
#use delay(crystal=16MHz)
#define LED PIN_B3
#define DELAY 1000
set_tris_b(0x00);
while(true)
output_low(PIN_B3);
delay_ms(DELAY);
delay_ms(DELAY);
Compiled with 5.015. Programmed (with Mach-X), and put it into a F88, on a bare breadboard (direct 5v supply from a bench supply, with a couple of extra 0.1uF capacitors by the chip pins), MCLR pullup. Used a 16Mhz crystal, since I did not have a 20MHz unit).
It is merrily toggling the pin... |
