NVM Write EEprom New PICs
Dagaca
PostPosted: Thu Aug 10, 2017 5:19 pm     Reply with quote
Hello.
The new PICs are a real headache.
I'm using pic 16f18325 and compiler version 5.070.
There is no way I can write in eeprom. I'm using the following function, (getenv doesn't work, this is other question)
#byte    NVMCON1 = 0x895
#byte    NVMCON2 = 0x896
#byte    NVMADRH = 0x892
#byte    NVMADRL = 0x891
#byte    NVMDATH = 0x894
#byte    NVMDATL = 0x893
#bit NVRD=NVMCON1.0
#bit NVWR=NVMCON1.1
#bit WREN=NVMCON1.2
#bit FREE=NVMCON1.4
#bit LWLO=NVMCON1.5
#bit NVMREGS=NVMCON1.6
void write_NVM (int8 addr, int8 data)
NVMREGS = 1;
    NVMDATL = data; //dato
    NVMDATH = 0;
    NVMADRL = addr; //direccion
    NVMADRH = 0x70;
    //unlock sequence
disable_interrupts(GLOBAL);
    WREN = 1; //enable writes eeprom
    NVMCON2 = 0x55;
    delay_cycles(1);
    NVMCON2 = 0xAA;
    delay_cycles(1);
    NVWR = 1;
    //end unlock operation
    while (NVWR){} //espera a que termine de escribir
    WREN = 0;
    NVMREGS = 0;
If someone can provide some solution I will be very grateful!!!!!!
PostPosted: Thu Aug 10, 2017 6:13 pm     Reply with quote
Here's the code produced by vs. 5.074. It looks like they fixed whatever
problem you had. You didn't post the .LST file from your version.
.................... write_eeprom(addr, data);
0013:  MOVF   INTCON,W
0014:  MOVWF  @77
0015:  BCF    INTCON.GIE
0016:  MOVLB  00
0017:  MOVF   addr,W
0018:  MOVLB  11
0019:  MOVWF  NVMADRL
001A:  MOVLW  70
001B:  MOVWF  NVMADRH
001C:  MOVLB  00
001D:  MOVF   data,W
001E:  MOVLB  11
001F:  MOVWF  NVMDATL
0020:  BSF    NVMCON1.NVMREGS
0021:  BSF    NVMCON1.WREN
0022:  MOVLW  55
0023:  MOVWF  NVMCON2
0024:  MOVLW  AA
0025:  MOVWF  NVMCON2
0026:  BSF    NVMCON1.WR
0027:  BTFSC  NVMCON1.WR
0028:  GOTO   027
0029:  BCF    NVMCON1.WREN
002A:  BCF    NVMCON1.NVMREGS
002B:  MOVF   @77,W
002C:  IORWF  INTCON,F
Test program:
#include <16F18325.h>
#fuses NOWDT
#use delay(internal=4M)
int8 addr;
int8 data;
while(TRUE);
Gabriel
PostPosted: Thu Aug 10, 2017 7:27 pm     Reply with quote
I need to learn how to do this as well.
I've needed it desperately for ages...
How do i know what addresses are free after i load a gigantic program?
Does the posted code work?
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Thu Aug 10, 2017 9:38 pm     Reply with quote
I'm not sure what you want to do.
Do you want to:
1. Write to NVM in the newer PICs ?
-or-
2. Write your own routines to replace non-working CCS routines ?
-or-
3. Something else ?
This seems like a separate topic than your first question.
If you're talking about finding unused Flash Memory, here's one way:
First, compile your program with no errors.
Then if you're using MPLAB vs. 8.92, go to the View / Program Memory window.
Then you can scroll through the entire Flash memory. For example with
a 16F PIC, every flash address that is equal to 3FFF is free.
Dagaca
PostPosted: Fri Aug 11, 2017 2:13 am     Reply with quote
Thanks PCM Programmer.
I just downloaded the demo version 5.074, now it works correctly.
Very good service, thank you very much!!!
Gabriel
PostPosted: Fri Aug 11, 2017 6:53 am     Reply with quote
I'd like to store values on the NVM as with EEPROM on older PICs.
This knowledge has always eluded me.
So from the little info on this thread:
CCS functions don't work in some versions.
I would need to compile first.
Check which addresses are free.
Code the available addresses to my code.
Recompile.
Success, this could have been avoided with eeprom?
PostPosted: Fri Aug 11, 2017 8:16 am     Reply with quote
Recompile.
That's not the way to replace a defective CCS function. You don't go in
at the machine code level and patch addresses.
You replace the whole function with a new, working one. Then give the
function a unique name, which is different from the normal CCS function,
so they don't conflict. If you give your function the same name as the
CCS function, the compiler will give you an error.
Example:
In the first post in this thread, Dagaca has written his own function
to replace write_eeprom(), and called it write_NVM().
There is an alternate way to replace a CCS function, using a #define
statement (called a 'macro'), but it's more complex. Using the method
shown in post #1 is OK.
PostPosted: Fri Aug 11, 2017 5:32 pm     Reply with quote
Gabriel,
I think I finally figured out what you really want. You want to use flash
memory as a substitute for eeprom, in older PICS that don't have eeprom.
CCS added a driver file to support this, probably around vs. 5.060.
Here is their news release page on it:
http://www.ccsinfo.com/newsdesk_info.php?newsdesk_id=192
The filename of the driver is: virtual_eeprom.c
Here is the file description:
                      Virtual EEPROM Driver
This driver uses two flash erase pages in program memory as virtual
eeprom memory. This driver uses write-balancing to avoid excessive
erasing of program memory.  This driver is optimized to use lower
eeprom addresses first; however, it is not a requirement to use the
available addresses in any particular order. The functions
which drive operation of the driver are detailed below.
The file was added after your compiler versions were released.
You could email CCS support and ask them to send it to you.
