andromeda92
[RESOLVED] Not enough RAM for all variables ? |
Posted: Wed Aug 02, 2017 3:30 am |
When i compile i have this error message.
PIC18F4550 with 16Mhz crystal
CCS version 5.0.15
This message appears when i include file font.h
This file is for driving ili9341 font, the array is biggest, but my question is:
Why does this same program work with mplab-x, does mplab-x optimize arrays?
When i use #device *=16, I have a same error.
main.h
#include <18F4550.h>
#device *=16
#device ADC=16
//#FUSES HSPLL
//#FUSES CPUDIV1
//#FUSES PLL4
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES VREGEN //USB voltage regulator enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOWRTC //Configuration registers not write protected
#use delay(crystal=16Mhz,clock=16Mhz)
Any idea ?
Last edited by andromeda92 on Wed Aug 02, 2017 11:21 am; edited 2 times in total |
oxo
Posted: Wed Aug 02, 2017 4:18 am |
How is the font defined?
I define my fonts as
Code: | const unsigned int8 font7x5[99][5] =
// char 32 == ' '
0x00, 0x00, 0x00, 0x00, 0x00,
etc... |
const puts it in ROM instead of (ROM which is copied to RAM) |
Posted: Wed Aug 02, 2017 4:26 am |
#=16, makes no difference at all on a PIC18 or above chip.
Declare the font as const. Then it'll be stored in ROM.
You keep talking about MPLAB as if it is a language. It isn't. MPLAB is an IDE, inside which you can be running quite a few different languages and variants (including CCS...). I'd suspect that the declaration you have (not shown) in 'font.h', results in the compiler being used (XC8 possibly), in storing the table in ROM. |
andromeda92
Posted: Wed Aug 02, 2017 7:56 am |
Yes you have right the array was defined as a const but i deleted keywork
const because i have this error:
attempt to create a pointer to a constant.
font.h
unsigned char Courier_New_Bold_20[] = {
* Font header
0x00, // Information
0x00, // ID
0x20, 0x00, // First Character
0x7E, 0x00, // Last Character
0x17, // Height
0x00, // Reserved
But if i add const
const unsigned char Courier_New_Bold_20[] = {
* Font header
0x00, // ID
0x17, // Height
0x00, // Reserved
the code below display the error message
TFT_SetFont(Courier_New_Bold_20, 1); <= error attempt to create a pointer to a constant
void TFT_SetFont(char *font_, char letterspacing)
font2 = font_;
letter_spacing = letterspacing;
height = TFT_CharHeight();
Original code for mplab-x is
typedef const unsigned char CUchar;
typedef unsigned char Uchar;
* Font header
0x00, // ID
0x17, // Height
0x00, // Reserved
void TFT_SetFont(CUchar *font_, Uchar letterspacing){
font2 = font_;
But in CCS char is unsigned char.
If i changed code for CCS:
void TFT_SetFont(const unsigned int8 *font_, char letterspacing);
void TFT_SetFont(const unsigned int8*font_, char letterspacing){
font2 = font_;
TFT_SetFont(Courier_New_Bold_20, 1); <= i have now plenty error message
The keyword const don't work in CCS, if i declare a function with keyword const, i have plenty error. |
Posted: Wed Aug 02, 2017 8:04 am |
Put back const.
Otherwise you are trying to put the whole font pointlessly into RAM....
Then add at the top of your code (after the processor include, but before anything else):
#DEVICE PASS_STRINGS=IN_RAM
This is a standard setting that is needed if you want to use any const with pointers.
Start with some basic code and learn the language, instead of expecting us to translate everything for you. |
andromeda92
Posted: Wed Aug 02, 2017 10:33 am |
I translated correctly the program for ccs, so for the constant works I was forced to put #device CONST = ROM.
I also put the clock at 48Mhz because I have timmings problems, for example the screen that turned white or time was erroneous, for example delay_ms (200) was 1 second.
Thanks for your help. |
Posted: Thu Aug 03, 2017 1:44 am |
Since CONST=ROM, is the default CCS behaviour, implies you were turning this off at some point.... |
