16c765 not working with a simple prog
Bob
PostPosted: Wed Jan 07, 2004 10:56 am     Reply with quote
Hit there. I am a new to this forum.
I tried everything but even the simplest program (see below) does not work.
It compiles fine, and I flash it with Icprog v1.05c.
After flashing Icprog tells me that the component is well verified but when powering up the chip, outputs are not initialized at high levels as they should!
I tried to put a delay to make sure it was not a timing issue, but same problem occurs.
Any suggestion would be most welcome as I am in a dead-end...
Bob.
_________________________________________________
#include <16C765.h>
SET_TRIS_A(0b000000); //configuration of port A (0=Output 1=Input)
SET_TRIS_B(0b00000000); //configuration of port B (0=Output 1=Input)
SET_TRIS_C(0b00000000); //configuration of port C (0=Output 1=Input)
SET_TRIS_D(0b00000000); //configuration of port D (0=Output 1=Input)
OUTPUT_HIGH(PIN_B1) ;
OUTPUT_HIGH(PIN_B2) ;
OUTPUT_HIGH(PIN_B3) ;
OUTPUT_HIGH(PIN_B4) ;
OUTPUT_HIGH(PIN_B5) ;
OUTPUT_HIGH(PIN_B6) ;
OUTPUT_HIGH(PIN_B7) ;
OUTPUT_HIGH(PIN_B0) ;
OUTPUT_HIGH(PIN_A0) ;
OUTPUT_HIGH(PIN_A1) ;
OUTPUT_HIGH(PIN_A2) ;
OUTPUT_HIGH(PIN_A3) ;
OUTPUT_HIGH(PIN_A4) ;
OUTPUT_HIGH(PIN_A5) ;
OUTPUT_HIGH(PIN_C1) ;
OUTPUT_HIGH(PIN_C2) ;
OUTPUT_HIGH(PIN_C3) ;
OUTPUT_HIGH(PIN_C4) ;
OUTPUT_HIGH(PIN_C5) ;
OUTPUT_HIGH(PIN_C6) ;
OUTPUT_HIGH(PIN_C7) ;
OUTPUT_HIGH(PIN_C0) ;
OUTPUT_HIGH(PIN_D1) ;
OUTPUT_HIGH(PIN_D2) ;
OUTPUT_HIGH(PIN_D3) ;
OUTPUT_HIGH(PIN_D4) ;
OUTPUT_HIGH(PIN_D5) ;
OUTPUT_HIGH(PIN_D6) ;
OUTPUT_HIGH(PIN_D7) ;
OUTPUT_HIGH(PIN_D0) ;
Neutone
PostPosted: Wed Jan 07, 2004 11:27 am     Reply with quote
How are you setting the fuses?
diego_huelva
PostPosted: Wed Jan 07, 2004 11:45 am     Reply with quote
The PIC16C765 only works at 24 MHz!!!
You can use a 24 Mhz crystal (fuse HS) or a 6 Mhz crystal (fuse H4)
(H HS 4k PLL in IcProg)
Bob
PostPosted: Wed Jan 07, 2004 2:14 pm     Reply with quote
I want to use the pic at 24Mhz,
i have to put "HS" in oscillator in ICprog ?
PostPosted: Thu Jan 08, 2004 5:52 am     Reply with quote
Yes!!!!! but only if you circuit has a 24 Mhz osc.
CCS code...
//if 24 Mhz osc (in ic prog put HS)
#include <16C765.h>
#device *=16
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=24000000)
//if 6 Mhz osc (in ic prog put H3 HS 4k PLL)
#include <16C765.h>
#device *=16
#fuses H4,NOWDT,NOPROTECT
