andromeda92
PIC18F4550 configuring SPI |
Posted: Mon Jul 31, 2017 7:06 pm |
I have a pic18f4550 with crystal 16Mhz, version of compiler is 5.015.
I want to drive ili9341 320x240 with spi.
The code it was for mplab-x but i have adapted it for ccs.
How do i configure spi ?
#include <18F4550.h>
#device ADC=16
#FUSES HSPLL
#FUSES CPUDIV1
#FUSES PLL4
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES VREGEN //USB voltage regulator enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC //Configuration registers not write protected
//#use delay(crystal=16Mhz, clock=16Mhz)
#use delay(clock=48Mhz)
on file ili9341.h
#define TFT_CS PIN_D0 //LATDbits.LATD0
//#define TRIS_CS TRISDbits.TRISD0
#define TFT_RES PIN_D1 //LATDbits.LATD1
//#define TRIS_RES TRISDbits.TRISD1
#define TFT_DC PIN_D2 //LATDbits.LATD2
//#define TRIS_DC TRISDbits.TRISD2
The main.c
#include <main.h>
//#USE SPI (MASTER, CLK=PIN_B1, DI=PIN_B0, DO=PIN_C7, MODE=2, BITS=8, STREAM=SPI_1)
#include "ili9341.h"
#include "ili9341.c"
int i;
char buffer1[20];
setup_spi(SPI_MASTER | SPI_MODE_2| SPI_CLK_DIV_4 );
TFT_Init();
TFT_SetDotSize(1);
TFT_RectangleRound(5, 115, 234, 314, 10, BLACK);
I have tested mode0, mode1, mode2, mode3, but it don't work.
How to calculate SPI_CLK_DIV_X ?
Do i need to put line
What is the difference with #use spi .., setup_spi and init_spi ?
Datasheet for ili9341 is here https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
My 2.4 tft spi 320x240 is http://www.winddeal.net/image/30209/30209-6.jpg
Example code for TFT_Init();
//#use fast_io(d)
//#use fast_io(b)
//#use fast_io(c)
// Declaration of global variables.
char *font, *font2;
char width, height, letter_spacing, dot_size = 0, frame_memory = TFT_VERTICAL;
unsigned int8 tft_x = TFT_W - 1;
// This function initializes the driver ILI9341.
void TFT_Init(void){
set_tris_d(0x00);
set_tris_c(0x00);
set_tris_b(0x00);
//TRIS_CS = 0; TRIS_DC = 0; TRIS_RES = 0;
output_high(TFT_CS); output_low(TFT_DC);output_low(TFT_RES);
TFT_Reset();
TFT_WriteCommand(0xCB); // Power control A (CBh)
TFT_WriteParameter(0x39);
TFT_WriteParameter(0x2C);
TFT_WriteParameter(0x00);
TFT_WriteParameter(0x34);
TFT_WriteParameter(0x02);
reset code
void TFT_Reset(void){
output_low(TFT_RES); delay_ms(50);
output_high(TFT_RES); delay_ms(150);
Thanks for your responses. |
Posted: Mon Jul 31, 2017 9:43 pm |
Quote: | I want to drive ili9341 320x240 with spi. |
According to the datasheet, the ili9341 can be jumpered to select 12
different interfaces. These can be i2c, SPI, and many parallel interfaces.
Do you know for certain that the SPI interface is selected ?
See page 26 of the data sheet, in this section:
7.1.1. MCU interface selection
Can you post a link to the website where you bought the lcd ?
They may have some documentation that tells which interface
the lcd has selected. |
Posted: Mon Jul 31, 2017 11:48 pm |
As a comment, the ILI9341 data sheet shows three wire SPI with the clock idle low, and all data transfers being done with the data stable on the rising edge of the clock. This is mode0.
He is selecting mode2, which has the clock idling high and all data transfers on the falling edge....
He talks about MPLAB, but MPLAB is not a programming language, but an IDE. If he is translating from Microchip-C, then this will have different SPI setups, and he should look at these.
On #use,
have a look at:
<http://www.ccsinfo.com/forum/viewtopic.php?t=54162&highlight=spi+spixfer>
<http://www.ccsinfo.com/forum/viewtopic.php?t=52644&highlight=spi+spixfer>
There are many similar threads.
#USE is more flexible and more powerful, but must be used with spi_xfer. It can handle both software and hardware SPI. Setup_spi, is the older command to just handle the SPI hardware, with more limited abilities.
The unit supports a maximum SPI clock of 10MHz for a read, and 6.66MHz for a write). SPI_CLK_DIV_4, will be trying to clock at 12MHz. Too fast. |
andromeda92
Posted: Tue Aug 01, 2017 2:11 am |
PCM programmer wrote: | Quote: | I want to drive ili9341 320x240 with spi. |
Interface is SPI, it work like a charm with arduino and the library adafruit ili9341. Tihis screen is only spi, other screen have uart/i2c/spi. |
Posted: Tue Aug 01, 2017 4:09 am |
Honestly you are starting from the wrong end.
First thing to do is get the SPI working with a minimum command.
Then translate the existing parallel mode ili9341 library:
<https://www.ccsinfo.com/forum/viewtopic.php?t=55040>
to use the SPI interface.
As have already pointed out, your SPI mode is wrong, and speed too fast for the chip. |
andromeda92
Posted: Tue Aug 01, 2017 5:14 am |
I have modified the code
setup_spi(SPI_MASTER | SPI_MODE_0| SPI_CLK_DIV_4 );
and modified crystal to
I do not know why it does not work because this code works on youtube, the only difference is that I replaced
that
void SPI1_Write(unsigned char data){
//SSP1CON1bits.WCOL = 0;
SSPBUF = data;
while(!SSPSTATbits.BF);
data = SSPBUF;
by
spi_write(parameter);
what is the equivalent for ccs for code below using spi function
void SPI1_Close(void){
SSPCON1 &= 0xDF;
Posted: Tue Aug 01, 2017 6:48 am |
You should change the fuse to HS, not HSPLL as well. Otherwise you may well still be clocking too fast.
setup_spi(SPI_DISABLED);
Is the command to switch the SPI off. |
andromeda92
Posted: Wed Aug 02, 2017 3:18 am |
thanks for the explanation |
