Program flow control and constants
astus
PostPosted: Tue Jan 06, 2004 9:06 pm     Reply with quote
I'm having a problem with an if statement. The evaluation of the if condition is incorrect. The code is below
long int egt;
#define START_TEMP_MAX 80L
egt = read_adc();
if( egt > START_TEMP_MAX ) {
para[ TURBINE_STATUS ] = ERROR_MODE;
para[ ERROR_CODE ] = TOO_HOT_FOR_START;
When simulation the if condition is always false as the statement code is never executed.
The code will work if the constant START_TEMP_MAX is assinged to an integer then tested in the if statement. This is a little confusing?
Adam Sad
PostPosted: Tue Jan 06, 2004 10:05 pm     Reply with quote
It works for me with a 16F877 and PCM vs. 3.178 (in simulation).
What PIC and version are you using ?
astus
PostPosted: Tue Jan 06, 2004 10:08 pm     Reply with quote
I'm using pic16f877 and pcm 2.734
