fprintf string
Orcino
fprintf string
PostPosted: Wed Jun 28, 2017 7:45 am     Reply with quote
Hi people,
The code below show -> AT+FTPPUTNAME="Test.
But what I need is -> AT+FTPPUTNAME="Test.txt"
What is wrong ?
Thanks.
char fileName[]="Test.txt";
fprintf(BT,"AT+FTPPUTNAME=\"%s\"\r",fileName);
PostPosted: Wed Jun 28, 2017 8:00 am     Reply with quote
It works for me in MPLAB vs. 8.92 simulator, compiled with CCS vs. 5.071.
I get this in the output window:
Test program:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#use rs232(baud=9600, UART1, ERRORS, stream=BT)
fprintf(BT,"AT+FTPPUTNAME=\"%s\"\r", fileName);
while(TRUE);
PostPosted: Wed Jun 28, 2017 8:06 am     Reply with quote
Nothing.
You are probably hitting another problem. Is the stream buffered?. One thing would be if you are using the CCS buffering, this throws away data if you overflow the buffer. So (for instance), my code doing the same thing:
      printf(GSMputc,"AT+FTPPUTNAME=\"%s\"\r", file_to_send); //set filename
Uses the subroutine 'GSMPutc' to send the characters, which encapsulates the CCS buffering as:
void GSMputc(int chr) {
   while (tx_buffer_available(GSM) < 2)
      ; //hold if buffer would overflow
   fputc(chr,GSM);
To prevent the CCS code from doing this (alternatively use your own buffering).
I see PCM_programmer also posted there was nothing wrong, while I was typing. Smile
Orcino
PostPosted: Wed Jun 28, 2017 10:05 am     Reply with quote
This is very strange.
If I remove the \" \" show -> AT+FTPPUTNAME=teste.txt
with \" \" show -> AT+FTPPUTNAME="teste.
But if I put a delay aftter fprintf
fprintf(BT,"AT+FTPPUTNAME=\"%s\"\r\n",fileName);
Show correct -> AT+FTPPUTNAME="teste.txt"
PostPosted: Wed Jun 28, 2017 10:12 am     Reply with quote
Post your PIC and your CCS compiler version.
Orcino
PostPosted: Wed Jun 28, 2017 10:21 am     Reply with quote
PIC is 24FJ128GB204 and version of the compiler is 5.071
PostPosted: Wed Jun 28, 2017 10:36 am     Reply with quote
So, something you are doing immediately after the print, is stopping the UART, or flushing it's buffer.
On your chip, you are losing what is in the hardware buffer. When you exit the print, there can be four characters still left to send. Something you are doing is stopping these from sending.....
If you need to do something to the UART, to wait for these to send, just use:
    while(Tx_buffer_bytes>0)
which will wait for the UART to finish transmission.
Orcino
PostPosted: Wed Jun 28, 2017 11:40 am     Reply with quote
Thanks Ttelmah and PCM programmer.
I was testing in debug mode, in release mode, it is working normally.
Orcino
PostPosted: Wed Jun 28, 2017 12:17 pm     Reply with quote
Guessing you had a breakpoint before the data had finished sending. Remember the hardware _stops_ when you break....
