TIMER problem
art
TIMER problem
PostPosted: Mon Jun 05, 2017 2:33 am     Reply with quote
I would like to calculate time before push button B6.
My problem is when i push button B6 it will not give actual time in second.
Please help to solve this problem
#include <18F4550.h>
#DEVICE ADC=10
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
#define INTS_PER_SECOND 91         // (48000000/(4*2*65536))
int8 v;      // A running seconds counter
int8 int_count;    // Number of interrupts left before a second has elapsed
#INT_RTCC                        // This function is called every time
void clock_isr() {                 // timer 1 overflows (65535->0), which is
                                   // approximately 91 times per second for
    if(--int_count==0) {           // this program.
      ++v;
      int_count = INTS_PER_SECOND;
      char c;
      unsigned char d;
      unsigned char key;
   usb_init_cs();
   while (TRUE)
         usb_task();
            if (usb_cdc_kbhit())
                 c=usb_cdc_getc();
                 if (c=='\n') {putc('\r'); putc('\n');}
                 if (c=='\r') {putc('\r'); putc('\n');}
                 while(true)
                  ART:
                  d = usb_cdc_getc();
                         if(d=='C')   // push C
                                while (key!=32) // push SPACE BAR to stop
                                 if(usb_cdc_kbhit())
                                   {key=usb_cdc_getc();}
                                                setup_timer_0(RTCC_DIV_2|RTCC_INTERNAL);
                                                set_timer0(0);
                                                enable_interrupts(INT_RTCC);
                                                     v = 0;
                                                   while(input(PIN_B6));    //Push Button B6
                                                     v=get_timer0();
                                                     printf(usb_cdc_putc,"%u seconds\r", v);
                                   } key=0; // to initialize 'key' not as SPACE BAR
alan
PostPosted: Mon Jun 05, 2017 4:43 am     Reply with quote
v=get_timer0();  ???????????
Are you sure. Doesn't v already contains the second value you are looking for.
art
PostPosted: Mon Jun 05, 2017 7:03 pm     Reply with quote
Hi alan,
Thanks, you are right !
