Exit for loop
art
Exit for loop
PostPosted: Fri Jun 02, 2017 2:06 am     Reply with quote
Hi ,
I'm trying to exit for loop using push button. However my code did not work as i plan.
I need it to give result as below:
0
1
2
3
0
1
2
3
art "when I push button"
However, my code output is:
0
1
2
3
art
0
1
2
3
art
Please show me how to do it.Here is my code
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
      char c;
      int i ,r;
      unsigned char d;
      unsigned char key;
   usb_init_cs();
   while (TRUE)
         usb_task();
            if (usb_cdc_kbhit())
                 c=usb_cdc_getc();
                 if (c=='\n') {putc('\r'); putc('\n');}
                 if (c=='\r') {putc('\r'); putc('\n');}
                 while(true)
                  ART:
                  d = usb_cdc_getc();
                         if(d=='A')   // push A
                                while (key!=32) // push SPACE BAR to stop
                                 if(usb_cdc_kbhit())
                                   {key=usb_cdc_getc();}
                                       init_ext_eeprom();
                                         for(y=0;y<=1000;y++)
                                                      printf(usb_cdc_putc,"%d\r" y);
                                                      printf(usb_cdc_putc,"%d\r" y+1);
                                                      printf(usb_cdc_putc,"%d\r" y+2);
                                                      printf(usb_cdc_putc,"%d\r" y+3);
                                                       if(input(PIN_B6));  //push button
                                                 printf(usb_cdc_putc,"art\r");
                                   } key=0; // to initialize 'key' not as SPACE BAR
alan
PostPosted: Fri Jun 02, 2017 2:26 am     Reply with quote
Try moving your printf to before the break command.
Every time the for loop completes it will print as there are no testing of a condition.
art
PostPosted: Fri Jun 02, 2017 8:35 am     Reply with quote
Hi alan;
i've rearrange the code as you advised,but it still give the same result.
When i compile, it shows message that below line "Code has no effect"
How to solve this problem ?
Kindly please reply
PostPosted: Fri Jun 02, 2017 8:59 am     Reply with quote
Read a C textbook....
In C, a 'statement', is a line of code, ending in a semi-colon, or a block of lines enclosed in {} brackets.
The IF statement executes the following statement.
You have a semi-colon after it (a statement...).
So what gets executed?.
