Using the 24 bit wizard
Nevillestone
PostPosted: Tue May 23, 2017 8:38 am     Reply with quote
Hi
Compiler Version PCD 5.071d
Chip 24EP256MC204
I've used the 24 bit wizard to generate the following code to get the PWM on this device working.
There is no output on B14 or B15.
I've distilled it down to bare bones and still nothing all the code is generated by the wizard other than the RL1 toggling that is happening.
Can anybody offer any advice on what could be wrong?
Header file:
#include <24EP256MC204.h>
#device ICSP=3
#device ADC=12
#use delay(crystal=20000000)
#FUSES WDT                      //Watch Dog Timer
#FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
#FUSES WPOSTS1                  //Watch Dog Timer PostScalar 1:1
#FUSES NOJTAG                   //JTAG disabled
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#use pwm(OC1,OUTPUT=PIN_B14,TIMER=2,FREQUENCY=150,DUTY=50)
#define RL1   PIN_C6
Main file:
#include <PWMTST.h>
int1 test;
   setup_adc_ports(sAN0 | sAN1 | sAN2 | sAN3 | sAN4 | sAN5 | sAN6 | sAN7, VSS_VDD);
   setup_adc(ADC_CLOCK | ADC_TAD_MUL_2);
   Delay_ms(1000);
   test=input_state(RL1);
    output_bit(RL1,!test);   //TODO: User Code
Neville
PostPosted: Tue May 23, 2017 9:24 am     Reply with quote
The wizard is worse than useless.....
Understand that it'll try to do what you tell it. Unfortunately, unless you tell it the right things, the results won't work. Since this implies you need to know what to tell it, you are much better off setting things up yourself.
Straight away, your ADC clock value is too fast (for 12bit mode Tad min is 117.6nSec, but you have 100nSec selected). A classic example of a 'wizard error'....
Now on the PWM, there are a couple of settings for the PWM, that #use doesn't give you access to. I'd suspect one of these is resulting in the PWM not running.
For instance, the default OC PWM setting has the fault input enabled, which will lock the output 'low'....
Look at the ex_pwm_pcd.c and setup the PWM yourself.
Nevillestone
PostPosted: Tue May 23, 2017 1:37 pm     Reply with quote
Thanks will try Crying or Very sad
Neville
Oreminclutch
PostPosted: Wed May 31, 2017 6:54 am     Reply with quote
Going to go ahead and second the fact that the wizard is useless.
top 3 best roulette chat sites
