ADC on PIC24HJ128GP204
Nevillestone
PostPosted: Wed May 17, 2017 8:41 am     Reply with quote
Hi, I'm looking for some help on the ADC of the PIC indicated.
I'm using compiler version 4.116 and accessing the ADC on PIC24HJ128GP204.
The code shown correctly sets up AN0 but as soon as I try any of the other ports Like AN5 or AN6 the result is just noise or 000.
I have simulated the code and see that AD1CHS0 address 328 does not seem to be set up correctly for AN5 or 6.
Is there something I'm missing when setting up the higher Analogue inputs or is this a compiler bug? i.e. Do I have to upgrade?
This chip has a number of S&H Opamps but I'm trying to use only channel 0 and individually accessing the analogue inputs.
I am getting a warning in the Simulator ADC-W0016: Minimum Tad time is 75 ns, it is 32 ns
But no matter how I adjust the ADC clock I can't get rid of the warning.
Any ideas that don't mean a upgrade will be greatly appreciated
setup_spi( FALSE );
setup_spi2( FALSE );
setup_adc_ports(sAN0|sAN1|sAN2|sAN3|sAN4|sAN5|sAN6|sAN7|sAN8|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2 | ADC_TAD_MUL_16);
//LCDFirstwrite();
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   CNT800=0;
   While(1)
      output_low(PWM1H);
      output_high(PWM1L);
      delay_us(DELAY);
      output_high(PWM1H);
      output_low(PWM1L);
      delay_us(DELAY);
      CNT800++;
      If (CNT800==800)
         CNT800=0;
         set_adc_channel(sAN0);
         delay_us(10);
         data=read_adc();
       set_adc_channel(sAN6);
         delay_us(10);
         data1=read_adc();
      set_adc_channel(sAN5);
         delay_us(10);
         data2=read_adc();
         lcd_gotoxy(1,4);
        printf(lcd_putc,"%04Lx",data);
        lcd_putc(" ");
        printf(lcd_putc,"%04Lx",data1);
        lcd_putc(" ");
        printf(lcd_putc,"%04Lx",data2);
      test=input_state(RL1);
      output_bit(RL1,!test);
Neville
PostPosted: Wed May 17, 2017 8:56 am     Reply with quote
set_adc_channel, takes a channel number.
So set_adc_channel(0); or set_adc_channel(1) etc.. Not a ADC multiplexer define. What is happening is you are selecting the wrong channel because you are using the wrong value on the select....
Nevillestone
PostPosted: Wed May 17, 2017 9:27 am     Reply with quote
Thanks, that does work. I'll define some names.
Neville
PostPosted: Wed May 17, 2017 11:23 am     Reply with quote
As a further comment, you do not need the delay between selection and sampling.
On most more basic PIC's you do. This is to allow time for the ADC to actually acquire the signal. However on more sophisticated ADC's like this one, it can be programmed into the setup:
The second value here, is how long it'll wait to acquire automatically. So 16 cycles of the ADC clock.
Now I've seen the simulators give incorrect warnings about the Tad. However we can't tell what your actual time is, since you don't post your clock frequency, and/or how the PLL is configured, or whether you are running in 10/12bit mode?.
Worth perhaps saying that unlike the more basic chips on the PIC24's and 33's, you can use ADC_CLOCK_INTERNAL. This runs at about half the maximum allowed for this chip. The time the simulator is quoting is wrong. The minimum Tad specified is 117.5nSec for 12bit mode or 76nSec for 10bit mode. Using the clock from the Fosc, only becomes necessary to get the fastest possible conversion.
