I can not move the brushless motor with 50 Hz
Zek_De
PostPosted: Mon Apr 10, 2017 10:27 am     Reply with quote
Hey friends,
I'm giving 50 Hz Pwm on ESC and no move. I just get periodic bip sound.
If I change PWM first bip stop and then again return bip.
What is wrong? PWM frequency ? My ESC is from Aliexpress.
https://tr.aliexpress.com/item/4x-2212-1000KV-Outrunner-Motor-4x-HP-30A-ESC-4x-1045-propeller-Black-Quad-Rotor/1983175325.html?spm=2114.13010608.0.0.oOAPJM
Mike Walne
PostPosted: Mon Apr 10, 2017 10:46 am     Reply with quote
We need a little bit more information.
For starters:-
What sort of drive does the motor require?
Which PIC/compiler are you using?
Can you show us your code?
What does your power drive look like?
I've had quick look at your link, tells me nothing.
Mike
PostPosted: Mon Apr 10, 2017 10:48 am     Reply with quote
Are you using a PIC ? Or are you using Arduino ARM Cortex ?
I suspect the ARM. In that case, you should look at Arduino forums, etc.:
https://dronesandrovs.wordpress.com/2012/11/24/how-to-control-a-brushless-motor-esc-with-arduino/
https://forum.arduino.cc/index.php?topic=270309.0
Zek_De
PostPosted: Mon Apr 10, 2017 10:53 am     Reply with quote
I'm using ARM stm32f4.
this is github
https://github.com/ZekDe/STM32F4xx
I m trying with PID output ,50 Hz .I didnt send codes because so long but if you want I will ...
PostPosted: Mon Apr 10, 2017 11:08 am     Reply with quote
That's what I thought. This is not an ARM forum. It's CCS only.
Zek_De
PostPosted: Mon Apr 10, 2017 11:51 am     Reply with quote
Yes but this is general question ,but I got it ,my mistake is 50 Hz (20 ms) but ESC works 1ms and 2ms okay thanks again
PostPosted: Mon Apr 10, 2017 12:02 pm     Reply with quote
It's not a general electronics forum. General electronic questions are
normally off-topic, but are OK if they are related to a CCS compiler
project, using a Microchip PIC microcontroller. ARM is off topic.
nailuy
PostPosted: Wed May 17, 2023 2:13 pm     Reply with quote
mabe is to late now, but mabe it help somewone.
you cannot make and electric engine (asincroic engine) to work in simple square wave at 50Hz. You must generate alternating sinusoid, by PWM of one microcontroller... to be apropiate to ideal sinusoid to alternate magnetic flux to create rotating copule to turn the rotor. If you heave simple square wave you will have simple magnetic change, without or less changing magnetic flux, In fast way without power to push the rotor.
This is simple to understand difference of square wave (simple digital) or sinusoid wave (PWM).
gaugeguy
PostPosted: Wed May 17, 2023 2:29 pm     Reply with quote
You must have missed in all of these very old postings that the OP was using an ESC (Electronic Speed Control) and not direct driving a motor.
PostPosted: Thu May 18, 2023 4:08 am     Reply with quote
Problem is of course that if this ESC takes a RC servo type signal he want's
a much finer resolution than a PWM will normally give. On the PIC better
to use a CCP to do this. Otherwise the resolution will be awful.
