Debug window not found!
JULIEN LAFFITTE
PostPosted: Wed Mar 15, 2017 3:32 am     Reply with quote
Hi
I'm working sometimes with 2 screens and now i don't find the debug window. I think it is out of my screen!? I don't find in compiler options or in installed files a way for reset the default position of the windows of the compiler. Does anybody have an idea for that?
PostPosted: Wed Mar 15, 2017 4:56 am     Reply with quote
Help if you said what environment you are working in?.
Assuming CCS IDE, then the 'debug windows' button, on the debug entry from the toolbar, bottom option 'reset debug windows'.
It might just be hidden. Two options up in the same menu 'show all'.
If you haven't got that toolbar enabled, then, Options, IDE, and you can enable this.
newguy
PostPosted: Wed Mar 15, 2017 6:33 am     Reply with quote
If it's a windows issue (window located off screen), holding the windows button and then tapping the right arrow key should bring the window onto your main screen.
JULIEN LAFFITTE
PostPosted: Wed Mar 15, 2017 8:54 am     Reply with quote
I'm on Windows 10 Pro 64bits version 1607 and i think the "reset debug windows" not work correctly...
PostPosted: Wed Mar 15, 2017 9:29 am     Reply with quote
It won't make them visible if they are hidden, and if they are still active/live, and simply off screen, then since they are OK, it won't show them. Use the win key method described by Newguy.
It will make them visible if they've been minimised, but not much else.
newguy
PostPosted: Wed Mar 15, 2017 10:09 am     Reply with quote
I've found that older versions of Altium Designer won't properly launch if you're using a variable number of monitors (Win 7). I normally run it on a 2nd monitor but if I try to run it using just my laptop's screen, Altium's main window will launch just fine but any pop up will launch on the (non-connected) 2nd screen. You have to ensure that you don't shift focus to another window by clicking anywhere after you attempt to launch the non-displaying window before using the windows key + right arrow trick. I think it's a windows issue because I know that I've found other programs will do the same thing if the last time I ran them they were on the 2nd monitor.
