General question about 12F510
filjoa
PostPosted: Mon Feb 20, 2017 6:27 pm     Reply with quote
Hi
I try make a little program with an old pic "12F510", but without success.
First I try make turn on an LED on the pins:
output_high(PIN_B0);
output_high(PIN_B1);
output_high(PIN_B2);
output_high(PIN_B3);
output_high(PIN_B4);
output_high(PIN_B5);
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
output_low(PIN_B4);
output_low(PIN_B5);
When I try this program only blink LED on B5 and B4.... someone know why?
Other test:
if (input(PIN_B4)==1)
output_low(PIN_B5);
Is possible the .h have problems?
best regards,
Filipe Abrantes
shson
PostPosted: Mon Feb 20, 2017 6:57 pm     Reply with quote
First off, B3 is an input-only pin as per PIC12F510 datasheet so you cannot use output_high nor output_low with B3.
Also the datasheet says on reset, all I/Os are configured as input. So use FIXED_IO to configure the pins as outputs:
#use FIXED_IO( B_outputs=PIN_B1, PIN_B2)
If the LED still doesn't blink, then it maybe because:
* incorrect clock/delay setting
* broken IO pin
* broken LED
Hope that helped
Eric
PostPosted: Mon Feb 20, 2017 9:53 pm     Reply with quote
The following code shows how to configure the pins for digital i/o.
#include <12F510.h>
#fuses INTRC,NOWDT,IOSC4
#use delay(clock=4M)
// This macro is used to set the OPTION register.
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
// The following code will setup the pins for digital i/o.
setup_adc_ports(NO_ANALOGS);
set_options(0xC0);   // Allow use of GP2 for i/o
while(TRUE);
shson wrote:
Also the datasheet says on reset, all I/Os are configured as input. So use FIXED_IO to configure the pins as outputs.
You don't need to do that. CCS uses "standard i/o" mode as the default.
The compiler will automatically add TRIS statements to set the pins to be
outputs when you use the output_low() or output_high() functions.
@Ttelmah:
I didn't use the setup_rtcc() or setup_counters() method to set the OPTION
register, because it either didn't setup all the OPTION bits exactly as I
wanted, or it required a lengthy source code line, and produced tons of
ASM code. The set_options() method gave me exactly what I wanted
and in only two lines of ASM code. Also, I only have the older free (but
complete) vs. 4.073 of PCB. The above comments are true for that version.
