Macro expansion fails in 5.069
alan
PostPosted: Mon Feb 20, 2017 1:47 am     Reply with quote
Goodday.
Have a problem in CCS 5.069 when using a macro expansion. CCS say it works on their side, so any ideas please.
I have not included any FUSES to make program small, but it can compile.
#include <33EP128GM604.h>
#use delay(internal=60000000)
#word MCU_PWMCON2 = 0xC40
unsigned int16 MCU_Temp;
#define PWMBUC1 2
#define make_pwmcon(x)   MCU_PWMCON##x
#define Enable_deadtime(x) {\
   MCU_Temp = (unsigned int16)make_pwmcon(x) & 0xff3f;\
   MCU_PWMCON##x = (unsigned int16)MCU_Temp | 0x0000;\ }
void main() {
  Enable_deadtime(PWMBUC1);  //Works in 5.024, but not 5.069
  Enable_deadtime(2);                     //Works in both versions
   while(TRUE) {
CCS Ver 5.024 output:
Memory usage: ROM=1% RAM=1% - 1%
0 Errors, 0 Warnings.
Build Successful.
CCS Ver 5.069 compiler output:
--- Info 300 "main.c" Line 2(1,1): More info: Actual Clock is 59983611
*** Error 12 "main.c" Line 13(27,28): Undefined identifier MCU_PWMCONPWMBUC1
1 Errors, 0 Warnings.
Build Failed.
PostPosted: Mon Feb 20, 2017 2:35 am     Reply with quote
That's actually correct......
Classic C problem of macro expansion. This is why 'make_pwmcon' exists, but you then don't use it on the second expansion.
The correct C syntax would be:
#define PWMBUC1 2
   make_pwmcon(x) = (unsigned int16)MCU_Temp | 0x0000;\ }
void main() {
   while(TRUE) {
From the manual of GCC:
Macro arguments are completely macro-expanded before they are substituted into a macro body, unless they are stringified or pasted with other tokens.
Note the 'unless'.
So when you use the ## inside the Enable_deadtime, the value is not expanded.
When you use 'make_pwmcon', the macro values are expanded when this is 'called', so it receives '2', not 'PWMBUC1'.
It sounds as if CCS have fixed an error, which just happened to allow your previous expansion to work....
alan
PostPosted: Mon Feb 20, 2017 2:40 am     Reply with quote
Thank you very much Ttelmah, I missed it that the arg on the left also need the substitution. Appreciate the time spend by you.
Regards
PostPosted: Mon Feb 20, 2017 3:06 am     Reply with quote
Nice to see someone using Macros. Smile
