Use bytes from array as int16 and int32
Futterama
PostPosted: Sat Feb 18, 2017 2:55 pm     Reply with quote
I receive some chars over RS232 and save those in a byte array.
Some of the data is a int16 (2 bytes) and some is a int32 (4 bytes).
How can I access the bytes in the array as int16 and int32 types without having to save it in a separate variable?
Example:
int8 array[6];
array[0] = 0x01;
array[1] = 0x02;
array[2] = 0x0A;
array[3] = 0x0B;
array[4] = 0x0C;
array[5] = 0x0D;
In the above array[0]-[1] contains the int16 and array[2]-[5] contains the int32.
So how can I access these data directly as the int16 and int32 data types for use in e.g. a printf?
Thanks.
PostPosted: Sat Feb 18, 2017 3:01 pm     Reply with quote
Use a union.
Create your own union for the array. So something like:
//If the array was (say) 128 bytes
union {
    int8 characters[128];
    int16 words[64];
    int32 long_words[32];
} array;
Then you have array.characters[] 0 to 127, array.words[] 0 to 63, and array.long_words[] 0 to 32, all talking to the same area of memory.
PostPosted: Sat Feb 18, 2017 3:02 pm     Reply with quote
one way would be to use the builtin functions of make16() and make32().
press F11 while your project is open to access the manual,select make16() from the index....
Jay
Futterama
PostPosted: Sat Feb 18, 2017 3:15 pm     Reply with quote
Thanks!
