I need to use 2 i2c memories on the same bus line and i referenced i2c codes in 24c128.c I can totally use one i2c mem but two i2c mem; i have no idea how to use it.One friend said that i need to configure i2c via sending addresses before R/W.I use functions in 24cxxx.c that :
write_ext_eeprom and read_ext_eeprom.Should i rewrite them all? If so,
how? How to configure 2 or more memories to R/W?
Thanks.
Analyzer
Mark
In your test code, you referenced 24c128.c?? Are you using a 24c128 or a 24lc256? Your orginal post said 24LC256. It makes a difference. The 2 devices are not addressed the same.
