Problem with PIC16f877 and 24lc256
Greg-
PostPosted: Wed Dec 24, 2003 6:15 pm     Reply with quote
I have connected my pic16f877 to a 24lc256 eeprom memory chip, i have used port e 0 and 1 for the SCL and SDA lines. I have compiled and loaded the EX_EXTEE.C example from the examples directory. when i attempt to read from the eeprom chip it always returns "FF" even though the value at the address is not "FF", as i preloaded soem data onto it using my pic/eeprom programmer, does anyone have any ideas to what may be going wrong?
Also at 20mhz and 5 volts what values should i be using for the two pull up resistors, and just to check, what format should the address be entered for the EX_EXTEE.C file when it asks for the memory address to read/write from.
Thanks in advance,
Greg
PostPosted: Wed Dec 24, 2003 7:17 pm     Reply with quote
At 20mhz and 5 volts what values should i be using for the two pull up resistors ?
This thread has a schematic which shows the resistor size
and the connections to the PIC.
http://www.ccsinfo.com/forum/viewtopic.php?t=17787
What format should the address be entered for the EX_EXTEE.C file
when it asks for the memory address to read/write from ?
From looking at the file, it looks like you should do this to read a byte:
(Answers shown in bold)
Read or Write: R
This assumes that you edited the EX_EXTEE.C file, to include the
proper driver file for the 24LC256. ie., the example file has this:
#include <2416.c>
But you should change it to this:
#include <24256.c>
And of course, if your programmer didn't really program the bytes
to some other value than 0xFF, then the EX_EXTEE.C program will
still read 0xFF. If it still doesn't work after doing all the changes
given above, then use the Write command of EX_EXTEE.C to write
a value such as 0x55 to address 0000, and then use the 'R' command
to read it back.
Mark
PostPosted: Wed Dec 24, 2003 7:31 pm     Reply with quote
Silly question, but did you change the following lines
#define EEPROM_SDA  PIN_B1
#define EEPROM_SCL  PIN_B0
to
#define EEPROM_SDA  PIN_E1
#define EEPROM_SCL  PIN_E0
Greg-
PostPosted: Wed Dec 24, 2003 7:52 pm     Reply with quote
Thanks for the replies!
Well yes, i changed the definitions to use E0 and E1 and also i tried the write command, and also i eddited the 2416.c file to say this:
#define EEPROM_SIZE 32768
instead of:
#define EEPROM_SIZE    2048
as i didnt seem to get the 24256.c in the driver directory. is that sufficient?
i used my programmer to read the data from the eeprom, and it shows up as having the data i have written to it previously(using the programmer), but it seems that the byte i try to write using the write command from EX_EXTEE.C doesnt seem to actually get written.
Mark
PostPosted: Wed Dec 24, 2003 8:08 pm     Reply with quote
Nope, the addressing is different for the 24lc256
24c16:
   i2c_write((0xa0|(byte)(address>>7))&0xfe);
   i2c_write(address);
24lc256:
   i2c_write(0xa0);
   i2c_write(address>>8);
   i2c_write(address);
void write_ext_eeprom(long address, int data)
  i2c_start();
  i2c_write(0xA0);
  i2c_write(address);
  i2c_write(data);
  i2c_stop();
  i2c_start();
  // until the write is complete
  while(i2c_write(0xA0))
    i2c_start();
byte read_ext_eeprom(long address)
  int data;
  i2c_start();
  i2c_write(0xA0);
  i2c_write(address);
  i2c_start();
  i2c_write(0xA1);
  data=i2c_read(0);
  i2c_stop();
  return(data);
PostPosted: Wed Dec 24, 2003 8:40 pm     Reply with quote
I didn't seem to get the 24256.c in the driver directory
You should have told us that up front.
It's available here:
http://www.cc.puv.fi/~t0101190/projekti/source/original/Drivers/
Though, in the version that's posted on that page, there is one error.
It has an incorrect eeprom size:
#define EEPROM_SIZE 16384
You should change it to this:
