mplab 6.12 - pcm - win98
Vidal
PostPosted: Fri Feb 21, 2003 6:36 am     Reply with quote
After executing the "mplab6.exe" to install the pcm within the mplab 6 in a W98-SE system, I receive this error:
- The following files failed to self-register:
Suite_CCSPic.dll
Any suggestions ?
PS.: With XP it runs ok !!
Vidal
___________________________
Original Post ID: 11952
Peter Barski
Re: mplab 6.12 - pcm - win98
PostPosted: Sat Mar 01, 2003 12:12 pm     Reply with quote
an outdated Win DLL is the cause. You should use Version 3.00.8449 or newer of the ATL.DLL . If you don't find a source, the CCS guys will send you one for sure.
Peter
:=After executing the "mplab6.exe" to install the pcm within the mplab 6 in a W98-SE system, I receive this error:
:=- The following files failed to self-register:
:= Suite_CCSPic.dll
:=Any suggestions ?
:=PS.: With XP it runs ok !!
:=Vidal
Original Post ID: 12255
Barry Gershenfeld
PostPosted: Wed Mar 12, 2003 8:36 pm     Reply with quote
:=Hi,
:=an outdated Win DLL is the cause. You should use Version 3.00.8449 or newer of the ATL.DLL .
Thanks for that advice! For some reason the one on my
laptop is dated 2/26/01, 21k, and version 2. But on
the desktop ... 6/01/99, 73k, the 3.00.8449, and
best of all, it works. So don't be fooled by the
file date like I was.
Barry
Original Post ID: 12595
